Axle option for this winters project - Great Lakes 4x4. The largest offroad forum in the Midwest
Old November 21st, 2007, 12:49 PM   #1
MichiganLarry
A pirate 200 yrs to late
MichiganLarry's Avatar
Default Axle option for this winters project
I have currently under my cj7 a c20 4.10's and d30 4.10's locked. I am running a healthy 360 and 35's. I already own a set (front and rear) of scout II d44's and a 28 spline ford 9" from an early bronco and an 86 cj d44.
I want to regear to 4.56 and want to lock both axles. I am considering spring over but haven't decided on that yet.
Which combination of axles that I own would be a good choice? Or should I just broom everything I own and go with d60's? I want to stay around 60" wms to wms.
MichiganLarry is offline   Reply With Quote
Old November 21st, 2007, 05:19 PM   #2
Nuzzy
likes him some Red Dog
Nuzzy's Avatar
You wanna stay with 35s for a while or go bigger?
Would help decided whether you want to dump $$into 44/9s or not...
Nuzzy is offline   Reply With Quote
Old November 26th, 2007, 06:07 AM   #3
MichiganLarry
Will probably stay with the 35's for right now. But I would like the option in the future of going bigger.
Old November 26th, 2007, 06:54 AM   #4
1x1_Speed_Craig
Simplify...
1x1_Speed_Craig's Avatar
The Ford 9" has a really low pinion, but I'm fairly certain you already know that. If the CJ-7 is going to be wheeled, I'd stay away from the 9" unless you're going with a high-pinion 3rd member (which is cool, but pricey).
If you're going spring-over, sell the '86 CJ-7 WT D44 and go with the Scout II D44 rear. The appeal of the '86 is that it's a bolt-in wide-track D44. If you're going spring-over, you're best off to sell the '86 D44 to someone who's running spring-under, and using the money toward the Scout II D44s (or whatever other axles you decide upon).
If you're going bigger than 36s or so at some point, you should probably be looking at building 3/4- to 1-ton axles.
Craig
Old November 27th, 2007, 11:46 AM   #5
ovrlnd
HURL SCOUTS
ovrlnd's Avatar
I swapped f/r scout 44's in my YJ converted to rear discs, chromo shafts running a 35" tread. if you got any q's let me know. nice thing is the scout d44 rears have the same shaft length left and right.
Old November 27th, 2007, 11:20 PM   #6
PavementPounder
PavementPounder's Avatar
Don't mod the 86 CJ D44. Sell it like Craig said.
If you truss the C20 rear (assuming you have 1-pc shafts), replacing it with the Scout axle won't be much of a change. Its really the front D44 that will be the improvement. If you do the front, I'd do the Scout rear with it just so you have matching track and brake fluid flow.
Old November 27th, 2007, 11:34 PM   #7
dirtrider
Dopey
dirtrider's Avatar
what is better about a scout rear 44 compared to cj d44, or is that he can get good money for the cj d44?
dirtrider is offline   Reply With Quote
Old November 27th, 2007, 11:41 PM   #8
PavementPounder
Money. Its the only bolt-in WT D44 rear option that exists for CJ's. If you're going SOA, there's no point in using it since you're going to put perches on any other axle anyway.
Old November 28th, 2007, 05:07 AM   #9
1x1_Speed_Craig
Simplify...
x2
Old November 28th, 2007, 08:35 AM   #10
Jeepaholic
Axle Guru Extraordinaire
Jeepaholic's Avatar
width also, the scout is a little wider than the cj
Old November 28th, 2007, 08:39 AM   #11
PavementPounder
Yes, but most people wouldn't use it by itself. What I was trying to say was run the Scout rear with its matched front (or another wider front axle) or don't use it at all if you're not going to narrow it.
Old November 28th, 2007, 08:45 AM   #12
Jeepaholic
Jeepaholic's Avatar
Agreed, just throwing it out there
Would work good with a scout front or 79 down waggy front axle.
Old November 30th, 2007, 01:49 PM   #13
MichiganLarry
Would I a have to cut off the inner c's and rotate them for proper caster?
Old November 30th, 2007, 01:50 PM   #14
MichiganLarry
Would work good with a scout of 79 down waggy front axle.
HUH????
Old November 30th, 2007, 02:04 PM   #15
1x1_Speed_Craig
Simplify...
Yes, but many people have matched a Scout II rear with an OEM CJ WT Dana 30 front, and the stance looks good.
Yes.
Old November 30th, 2007, 02:07 PM   #16
MichiganLarry
Currently have 4" lift springs. What would the guru's suggest with a spring over? Would like to get something that is a little less stiff.
Old November 30th, 2007, 02:17 PM   #17
Quagmire
I can has layinframe
Send a message via Yahoo to Quagmire
Stock springs springover will net you about 1 more inch of height and more flex
Google first.....ask questions later
Actually, the new rule of thumb is you should make your tires bulge slightly more then skooterbuilt when he's wearing his tight ladies pants
Quagmire is offline   Reply With Quote
Old November 30th, 2007, 03:12 PM   #18
MichiganLarry
cj springs or yj springs?
Old November 30th, 2007, 03:30 PM   #19
Quagmire
well i have a coilsprung rig so i'm not sure i think the yj springs are longer
Old December 3rd, 2007, 01:12 PM   #20
ovrlnd
HURL SCOUTS
ovrlnd's Avatar
I really like my scout II axles. the inner knuckles have been removed and reset.
Page generated in 0.54486 seconds with 83 queries
