O2 sensor compatibility - Great Lakes 4x4. The largest offroad forum in the Midwest
Old November 20th, 2007, 09:33 PM   #1
albersondh
FNG
albersondh's Avatar
Default O2 sensor compatibility
I’m doing an EFI swap onto my 87 pick up (22R) and I need to swap the one wire 02 sensor from my donor EFI (88 pick up). The 02 sensor has a flange with two holes and is mounted to the same on the OEM exhaust manifold. I’m running a header and I want to know if there is a compatible one wire 02 sensor that is screw in without a flange? By compatible I mean one wire, and able to produce the same voltage feedback range as the OEM sensor. In any case it would have to be compatible with the Toyota ECU?
Also I want to ditch the stock 88 EFI air box for a cone air filter. My air flow meter has a flange with four studs on it that bolts to the air box. Does somebody make an adapter from the square air meter flange to a 3 or 4" tube? I know Downey sells a complete kit but I just want the adapter so I can do my own plumbing.
albersondh is offline   Reply With Quote
Page generated in 0.23218 seconds with 26 queries
