Upper steering stabilizer bolt - Great Lakes 4x4. The largest offroad forum in the Midwest
Old March 13th, 2006, 09:18 PM   #1
Kawierider
Kawierider's Avatar
Default Upper steering stabilizer bolt
If you are running, or about to run a rough country steering stabilizer, or any other steering stabilizer that uses a tapered insert on a normal bolt be sure to coat the outside of the spacer (the side that mates with the tapered bore) with anti-seize or some other corrosion inhibiting coating.
If you do not, two years later when the stabilizer wears out and you go to install a monroe or other stabilizer you will not be able to get this spacer out when you go to insert thier already-tapered bolt.
that is all.
Old March 15th, 2006, 09:07 AM   #2
xjmichigan
xjmichigan's Avatar
:tonka: its been two years since i replaced mine last (had to drill it out)
Page generated in 0.22340 seconds with 29 queries
