97 f150 no start.....sometimes... - Great Lakes 4x4. The largest offroad forum in the Midwest
Old November 19th, 2007, 10:15 PM   #1
nate4d
Gnarley Davidson
nate4d's Avatar
Send a message via AIM to nate4d
Default 97 f150 no start.....sometimes...
has a 4.6L and is a 97 with the TPS recently replaced and fuel pump recently replaced. will crank all day but wont fire sometimes. will start with a lil bit of carb-cleaner/starter fluid. only happens sometimes. sometimes cold (sitting for awhile) or sometimes after being shut off for only 5 minutes. its got me all confused. any help will be appreciated.
nate4d is offline   Reply With Quote
Old November 19th, 2007, 10:26 PM   #2
Squishy
Needs More Cowbell
Squishy's Avatar
Send a message via AIM to Squishy
Check the ignition parts... I had the same problem with an entirly different make. It would crank and crank and crank, but never start. Maybe ignition coil, or something along those lines?
Just shooting out ideas.
Squishy is offline   Reply With Quote
Old November 19th, 2007, 10:37 PM   #3
nate4d
Gnarley Davidson
nate4d's Avatar
thanx bud ill check it out.
Old November 20th, 2007, 08:21 AM   #4
GreaseMonkey
Pew pew!
GreaseMonkey's Avatar
I don't know what sensor Ford uses to reference ambient air when starting, but check out things like the IAT, MAP, or coolant temp sensor. Find out what sensor Ford uses and do some checks on it with your multi-meter.
It sounds like the PCM isn't getting the correct temp reading when you fire it up.
Old December 17th, 2007, 01:30 AM   #5
Never_Evil
There is a cam position sensor in one of the heads and a crank position sensor near the harmonic balancer. If there is moisture or corrosion in the connectors, you found your problem, dont forget to check them too. Hook alligator clips on each of the prongs and pass either a chunk of iron or a magnet and watch for a needle sweep or if its digital a range sweep. Use the resistance mode (upside down horse shoe).
Page generated in 0.21556 seconds with 38 queries
