Hitch Question - Great Lakes 4x4. The largest offroad forum in the Midwest
Old November 19th, 2007, 01:52 PM   #1
daddyman
daddyman's Avatar
Default Hitch Question
Is anyone using a weight distribution hitch on their 1/2 ton tow rig to haul a car hauler? Is it needed? Yes? No?
Got my trailer Saturday, I'll be hauling it with a '02 Tahoe. Not to sure if I need the WDH or not. I don't really see anyone using one, but then I don't see tow rigs like we'll be using eigther.
What's your thoughts on this?
daddyman is offline   Reply With Quote
Old November 19th, 2007, 02:30 PM   #2
Viperdave
A-1 Dave Costa
Send a message via AIM to Viperdave
most people dont use them on car trailers because you can use the vehicle on the trailer to balance the load. this is assuming that the truck is setup to handle proper tongue weight.
with that being said, you shouldnt have any problems, i towed full size jeeps on trailers with a 1500 suburban and didnt have any sag issues
Viperdave is offline   Reply With Quote
Old December 7th, 2007, 12:33 AM   #3
Kawierider
Kawierider's Avatar
you will be ok without one provided the truck can handle enough tonque weight to let the trailer not sway.
On the other hand the hitch on that truck is not rated to tow that weight without a WD setup so you 'should' use a WD hitch. Also note that most standard ball-mounts are not rated at that weight either. You want to look for a solid ball-mount not a square-tube one. (not that youll have problems there either)
Our WD setup makes our van drive, handle and brake much better when towing, and the sway control is amazing in windy weather, but we dont NEED it unless we are towing the heaviest of heavy loads.
Old December 7th, 2007, 07:45 PM   #4
Motor Slut
I put the Ick in Dick.
Motor Slut's Avatar
open deck trailer should be fine
We use one on our enclosed race trailer because it weighs more and grabs the wind like you wouldn't believe.
Old December 12th, 2007, 08:53 PM   #5
CreativeFab
used to be Ironman
CreativeFab's Avatar
If you do find that you want to run a WD setup give me a shout, I will quote you a price on several brands I carry.
Pat
ironmanoffroad.com
989 832 7538
Old December 13th, 2007, 12:13 AM   #6
busyfixin
Balls Deep
busyfixin's Avatar
its probably not needed, but in my experience the trailer will ride alot better.
Old December 13th, 2007, 08:04 AM   #7
roll-bar Bob
roll-bar Bob's Avatar
with a WD you can pull that rig up closer to the tow rig giving you more tong weight, and less Bouncy Bouncy
Old December 13th, 2007, 08:09 AM   #8
Bratworst
Bratworst's Avatar
It's not a bad investment either. You'll never know when you may need it.
Some kits can be switched from trailer to trailer in about 15 min. of work.
Bratworst is offline   Reply With Quote
Old December 13th, 2007, 12:04 PM   #9
CreativeFab
used to be Ironman
Good point, even the WD head, as long as it is adjustable, can be used on another vehicle. You know, when your buddy wants to borrow your trailer
Old December 15th, 2007, 04:18 PM   #10
Eric 93 YJ
Northwest Ohio Crawlers
Eric 93 YJ's Avatar
I towed for years w/o a wd hitch. Now that I have one I love it! I have a US Cargo Car Hauler trailer and it doesn't sway any, just follows my F-150. Plus in the snow it helps with keeping the front tires on the road for better steering.
93 YJ
http://www.northwestohiocrawlers.com
Eric 93 YJ is offline   Reply With Quote
Old December 15th, 2007, 11:07 PM   #11
jsmtam90
Old School Jeeper Club
jsmtam90's Avatar
long hauls I would use a wd hitch, makes the ride much smoother w/a 1/2 ton truck and puts the weight on your front end to help w/steering control. Short trips I would use a sway bar controler with trailer load well balanced.
jsmtam90 is offline   Reply With Quote
Page generated in 0.26202 seconds with 56 queries
