99 grand caravan trans prob - Great Lakes 4x4. The largest offroad forum in the Midwest
Old November 19th, 2007, 06:12 AM   #1
Silver Bullet
Livin the American Dream
Silver Bullet's Avatar
Default 99 grand caravan trans prob
well my wifes van seems to have a problem. when the van is cold first gear slips real bad leaving the van motionless like it is in nuetral. once it warms up or you get into second it is fine, but if you slow down while it is still cold first will still slip. any ideas on what to do about this. thanks in advance adam.
Silver Bullet is offline   Reply With Quote
Old November 19th, 2007, 08:23 AM   #2
JeepInABox
In too deep
JeepInABox's Avatar
Low reverse clutch pack seals leaking due to seal hardening
Replace the seals in both clutch packs and drive for another 100,000 miles
Old November 19th, 2007, 09:37 AM   #3
Tom
Because racecar
Tom's Avatar
This is correct. There is an update also for the low reverse piston which includes a new piston retainer and lip seals.
Old November 19th, 2007, 09:38 AM   #4
xjmichigan
xjmichigan's Avatar
let is warm up
Old November 20th, 2007, 06:52 AM   #5
Silver Bullet
well, i have no idea how to do that or any idea about trans. any clue on what is involved in that or what it would cost.
Old December 7th, 2007, 04:49 PM   #6
Silver Bullet
gonna change the fluid and filter and see if i can get through the winter. what is the diiference between dexIII and dex4
Old December 7th, 2007, 05:10 PM   #7
xjmichigan
xjmichigan's Avatar
As it says on the dip stick "fluid 7176" you should be using ATF+3
I read somewhere before that ATF+3 is not synthetic, ATF+4 is synthetic
ATF+3 does not equal Dex/MercIII
Old December 7th, 2007, 06:06 PM   #8
Silver Bullet
thats what i meant atf III atf 4. so 4 is just synthetic.
Old December 9th, 2007, 07:59 PM   #9
Silver Bullet
well changed the filter and flushed the system. no metal shavings just a little powder on the magnet. fluid smelled horrible and was real dirty. had a leak going into the cooler, fixed it. i add fluid to appropriate level and later it is low again. fill and low again. no visible leaks. where can the flud be going or does it take some time to get the converter filled up. well see if it keeps slipping. also added some lucas trans fluid.
Old December 9th, 2007, 10:29 PM   #10
xjmichigan
xjmichigan's Avatar
it had an external leak or leaking in to the coolant?
Old December 10th, 2007, 06:13 AM   #11
Silver Bullet
external at the return line. but now i fill it and recheck it later and it still shows low. with draining it out will it do that untill everything gets filled back up completely.
Old December 10th, 2007, 07:41 AM   #12
Tom
Because racecar
Tom's Avatar
If you only dropped the pan, it should only take approximately 4 quarts. are you checking the fluid when the van is warm?
Old December 10th, 2007, 07:00 PM   #13
Silver Bullet
yes sir the van was warm. were could the fluid be going if there are no signs of leaking.
also what is you last name. i think i might know some people that associate with you.
Old December 11th, 2007, 08:56 AM   #14
Tom
Because racecar
Tom's Avatar
the only place it could go is the radiator, but usually they will mix in the trans also. open up the radiator and see if it looks like a strawberry milk shake.
Page generated in 0.26938 seconds with 65 queries
