Trans temp gauge - Great Lakes 4x4. The largest offroad forum in the Midwest
Old November 17th, 2007, 03:04 PM   #1
nd4spd71
nd4spd71's Avatar
Default Trans temp gauge
I want to install a trans temp gauge in my 1994 3/4 ton Chevy truck. I have a couple of questions about it though.
1. Where is the best place to mount the temp sending unit? I would assume on the line coming out of the trans, but am not sure about that.
2. What is the normal temp operating range for an auto trans? And what is the danger zone?
By the way the trans is a 4L80E.
Any input would be great. Thanks in advance.
nd4spd71 is offline   Reply With Quote
Old November 19th, 2007, 02:11 PM   #2
Kodiak450r
Keep on truckin
Kodiak450r's Avatar
you can put it in the oil pan or in the line to the cooler. i prefer to put it in the pan. transmissions like temps below 210. the colder the better. anything above 250 and you start cooking the fluid and hardening seals etc..180-190 is usual temp when not towing for a 4L80.
Old November 19th, 2007, 02:25 PM   #3
Tom
Because racecar
Tom's Avatar
Kodiak is correct. If you want to put it in-line, install it in the uper line coming out of the trans.
Old November 19th, 2007, 07:55 PM   #4
Mclovin
"The Situation"
Mclovin's Avatar
i thought it was going INTo the cooler ? to see how hot it is before cooling ? but im gona say u are right based on your SN :tonka:
my dodge runs at 100 degrees (verified with scan tool) mines run in line with the trans cooler going INTo the cooler i beleive
Old November 20th, 2007, 07:36 AM   #5
Tom
Because racecar
Tom's Avatar
The upper line on the side of the case is the one going to the cooler. You want to know what it is at its hottest point. I apologize if i was not clear.
Old November 20th, 2007, 08:49 AM   #6
nd4spd71
nd4spd71's Avatar
Thanks guys for the input.
Page generated in 0.23289 seconds with 41 queries
