Dana 30 gear change - Great Lakes 4x4. The largest offroad forum in the Midwest
Old November 16th, 2007, 03:37 PM   #1
Fraser
Fraser's Avatar
Default Dana 30 gear change
i have two d 30's, an older one w/ 3.55's and the smaller axle joints, and a 99 w/ 3.07's and the bigger axle joints(and better brackets on the housing). My buddy told me to stick the 3.55's into the 99 housing, b/c of my bracket condition issue. I am just wondering what is involved with this, gear set uop wise etc, I am prob going to get help doing this, and plan on picking up a master rebuild kit for the axle. just lookin for some tips/ suggestions to go along with this.
Old November 16th, 2007, 04:09 PM   #2
ajmorell
My guess is the older one is set up for leafs. If that isn't the case then you should just put the axle with 3.55s under your Jeep and swap all of the newer bigger & better stuff over to it.
Old November 16th, 2007, 07:06 PM   #3
Fraser
Fraser's Avatar
no, the older one is an xj axle, the passenger coil bucket is rotted out
Old November 16th, 2007, 07:08 PM   #4
Fraser
Fraser's Avatar
Originally Posted by One Arm Steve View Post
You can put the shafts with the larger u joint in your current axle too.
duh, whoops, i wasnt thinkin too good
Page generated in 0.21322 seconds with 35 queries
