EFI swap question. - Great Lakes 4x4. The largest offroad forum in the Midwest
Old November 15th, 2007, 10:51 PM   #1
albersondh
FNG
albersondh's Avatar
Default EFI swap question.
Iím starting my EFI swap next week and I have one question (for now). It seems everyone that converts from carb to OEM EFI sources an EFI fuel tank for the swap. I understand the benefit of this but Iím wondering why not just use the carb fuel tank? Mine (87 22R) has an out-put, return, and a vent. So it seems to me like I could just run an external pump. Unless there is an issue with the sending unit line diameter being too small. I refurbished my sender and braised in new 1/4" copper lines. So what do you think, do I have to get a new tank? I donít want to run a cell so thatís not an option.
The way my other EFI cars are plumbed fuel goes from the tank, to the rail, past the reg, and then returns to the tank. So it appears I have all the plumbing I need?
albersondh is offline   Reply With Quote
Old November 15th, 2007, 11:12 PM   #2
brimy311
Smells like a Fork Liftis
brimy311's Avatar
You can run an external pump, ES2000 is a good pump made by ford. I have used this pump on my 22re before, worked fine.
JcrOffroad.com
Like us on Faceook!
Old November 16th, 2007, 07:54 AM   #3
albersondh
FNG
albersondh's Avatar
You used this pump (ES2000) on a 22RE (EFI) motor, with a 22R (carbureted) fuel tank?
Old November 16th, 2007, 10:29 AM   #4
brimy311
brimy311's Avatar
no, used it with a fuel cell. But it should not matter.
JcrOffroad.com
Like us on Faceook!
Old November 16th, 2007, 11:10 AM   #5
MrGrey
propane evangelist
MrGrey's Avatar
screw it and just go propane....
MrGrey is offline   Reply With Quote
Old November 16th, 2007, 01:38 PM   #6
albersondh
FNG
albersondh's Avatar
Does anybody know the ID of OEM EFI sending and return lines? Im sure its metric so please convert to the closest US standard if you can?
Whats nominal fuel PSI? for OEM EFI (22RE).
Thanks for the help, I need to bang this out over T-giving leave, I got the week off so that should be plenty of time assuming I dont end up having to source long lead time items.
Old November 16th, 2007, 01:49 PM   #7
brimy311
brimy311's Avatar
long read, might be here:
http://www.pirate4x4.com/forum/showthread.php?t=316661
JcrOffroad.com
Like us on Faceook!
Old November 23rd, 2007, 07:50 PM   #8
88yj
collecting parts
88yj's Avatar
Send a message via AIM to 88yj
Just checking in to see how this turned out. I'm about do do the same thing, but I've been dragging my feet with it.
88yj is offline   Reply With Quote
Old November 26th, 2007, 12:40 PM   #9
albersondh
FNG
albersondh's Avatar
I have the injectors out getting cleaned and balanced (RCI). Everything else is cleaned and pretty much ready to go in. Im going to use a Bosch 1 wire, screw in, 02 sensor ($25.00). If it works great, if not Im only out $25.00. The engine harness is all cleaned up (from donor 88) and I plan on just overlaying it and powering it up. I think some people swap the entire harness; I have no idea why you would do this when the engine harness is pretty much stand alone for the EFI... Ill keep this updated and post up some pics.
Old November 26th, 2007, 12:52 PM   #10
88yj
collecting parts
88yj's Avatar
I read a lot of the EFI stuff is in the dash wiring? Maybe it's wrong. Let me know how it works out since I have the same swap to do in my truck. I have 2 complete donor harnesses.
Old November 30th, 2007, 06:25 PM   #11
albersondh
FNG
albersondh's Avatar
Looks to me like the engine/EFI harness (see below pic) covers most if not all of the EFI controls. The harness terminals at the ECU, so I think I can just power it up and Im good. Im still waiting on my injectors from RCI to get back befor I realy dive into it. I have all my gaskets and junk together so Im hopeing its a weekend job once the injectors come back.
[IMG][/IMG]
Old November 30th, 2007, 08:11 PM   #12
88yj
collecting parts
88yj's Avatar
Like I said, I'll be watching this thread. Good luck with it. I want to do mine next month.
Old November 30th, 2007, 09:36 PM   #13
brimy311
brimy311's Avatar
I have always just used the entire harness from an EFI truck for installing this. I know on POR they have a EFI swap, splicing into the carbed truck harness. I am not sure. Probably wont get much help here.
JcrOffroad.com
Like us on Faceook!
Page generated in 0.27135 seconds with 62 queries
