| Home | Register | iTrader | Members List | Calendar | Search | Today's Posts | Mark Forums Read | Store | Photo Gallery | Chat |
Thread Tools | Display Modes |
#1 |
Douche Mod #1
How to: Tj/Xj/Yj 30 with 44 knuckles
Though I would do a write up of sorts on the dana 30 I built.
The goal was to use all easy to get parts, IE stock tj inners. But to also have high steer and lockouts. And not have to build another truss for the driver side uca :stan3: . Started out as a Xj hp 30, you will also need a cj dana 30 for tubes and inner C's, and dana 44 knuckles and hubs. First cut these off ![]() I used the shafts to measure for the amount of tube I needed to leave on the CJ dana 30 knuckles ![]() Cut ![]() ![]() Doing the other side ![]() Mocked up ![]() I used 2" 1/8" wall dom as a internal sleeve ![]() ![]() One side done ![]() Just a couple of brackets left to weld on.
Axle Guru Extraordinaire
#2 |
Low Range Drifter
That's pretty sweet. Much better than the one BillaVista did many years ago.
2001 Wrangler |
#6 |
Smells like a Fork Liftis
Cool. You should post the benifits of this, say over a Newer d30 housing and shafts :)
#7 |
Douche Mod #1
You mean something along these lines?
PRO's Lockouts Serviceable bearings bigger brakes stronger ball joints high steer for less $$$ parts availability added tube strength (if you sleeve the whole tube) CON's added width welding required (for some) wheel bolt pattern changes I have in axles: $60 for a waggy 44 (flat tops, spindles, brakes) $50 for ford hubs and rotors $100 for the XJ 30 -$10 for the cj 30 :tonka: Plus high steer arms and machining for ~$200. Add a super 30 inners and locker and be really close to 44 strength, I am gonna run stock shafts for now and see how they hold up
#8 |
10 0011 10101
You can also use Chev. 10 bolt outers for this -Kevin at Jeeperz Creeperz told me he'd done one a while back for a guy this way. It's a pretty cool idea for a cheap axle upgrade.
Edit: Didn't the billavista one need custom axle shafts? How do you get around that? |
#9 |
Douche Mod #1
He just cut off the stock inner c's but saved the tube, then installed the cj c's. But the newer 30 knuckles have a longer c so to switch to the 44 stuff you need to add about a 1" of tube. Which is why I cut and sleeved the old 30 knuckles. Does that kinda make sense?
This whole axle, including all the new steering and 4:88's installed will cost less than the warn hub conversion by itself. And I gain strength in places it doesn't, plus replacement parts are a auto store away
#11 |
Low Range Drifter
can you grab a measurement between wheel mount surfaces?
2001 Wrangler |
#12 | |
#13 |
Low Range Drifter
somewhere in there he mentions he's using stock XJ D30 inners with stock D44 outers, no resplining needed
2001 Wrangler |
#14 |
Douche Mod #1
Yes I will hopefully have it all put together tomorrow
I was roughly guessing 62" though Stock 30 tj inners (297 joint) to the fsj/chevy stubs. Easy to find replacement shafts. Not ONE custom shaft
#15 |
#17 |
Now abduction FREE!
Was the ID of the CJ inners the same as the XJ inners or no? Could you have just swapped inners on the stock tube?
Good write-up. |
#18 |
Douche Mod #1
Yes, you can they are both 2.5" od, but would have to have custom inner shafts made. BillaVista did it that way, his writeup http://www.pirate4x4.com/tech/billav...HybridAxle.htm
#19 | |
Douche Mod #1
Finished pics
#20 |
"The Situation"
dude you change front axles in your TJ more than i change my socks..
06' GMC 2500HD 6.0 00' Honda 440EX 11:1, stg 2 Hot Cam, T-4, W.B. CDI 89' Chevy S-10 "kinda" D44's D300 38's FOR SALELowlife Offroad "UNIONS" Protecting the Lazy American worker |
| Thread Tools | |
| Display Modes | |
