8.8 tech - Great Lakes 4x4. The largest offroad forum in the Midwest
Go Back   Great Lakes 4x4. The largest offroad forum in the Midwest > 4x4 Talk > Jeep Tech > Jeep tech FAQ
Jeep tech FAQ Look here first!
Old November 10th, 2005, 09:52 PM   #1
jeepfreak81
81 inches of fun
jeepfreak81's Avatar
Default 8.8 tech
Figured I would post my links to 8.8 tech i have aquired, never made my own because these were more then sufficient. If people search I hope this will come up for them.
at a glance...
These are the codes you will need when out shopping for your 8.8
Axle tag codes:
3L73 = 3.73 LS
4 10 = 4.10 open
4L10 = 4.10 LS
and so on
Door codes:
43 Open 3200 3.08
41 Open 3200 3.27
42 Open 4.10
46 Open 3.73
45 Open 3200 3.55
D4 Limited Slip 3200 3.73
D2 Limited Slip 4.10
L73 Limited Slip 3.73
Here's all the specs, measurements, and misc crap about the 8.8 you'll ever want to know.
Ford 8.8 specs:
Weight (complete assembly w/ brakes etc.): 174 lb.
Axle shaft strength: 6,500 (lb. ft.)
Drivers side Ford brake hose #:F5TZ-2282-A
Passenger side brake hose #: XL2Z-2282-AA
Bolt size (U-joint flange to yoke) is: 12 x 1.75 x 30 mm
Driveshaft Flange: Spicer Part Number 2-2-1379
Measurements:
O.D. of tubes: 3.250".
Tube thickness: .250" (some are .188!)
Ring gear diameter: 8.800".
Ring gear bolts: 7/16" dia. (qty. 10).
Pinion diameter/splines: 1.625 / 30.
Axle shaft/splines: 1.320 / 31.
Rotor thickness (where it mounts to axle is .250").
Overall width 59.625" (the F8.8 is .950" narrower then a TJ Dana 35).
Hole diameter for ABS sensor in top of housing: .811".
Centerline of housing to C/L of pinion difference is 3.875" toward the P/S.
Pinion offset: P/S to C/L of Pinion, 27-3/4" (no rotor on axle), D/S to C/L of Pinion, 31-5/8" (no rotor on axle). (this measurement is 2.5" more offset to the P/S then a TJ Dana 35).
all taken from
http://members.cox.net/quanno/ford88.html
there are comparison pics to the D35 there as well
also www.stu-offroad.com has TONS of info... not just on 8.8 axles
Old November 10th, 2005, 10:16 PM   #2
Roadhouse
DrivewayJeeper
Roadhouse's Avatar
Good info Jake, thanks
Old November 11th, 2005, 03:18 AM   #3
Monkeyevil
I <3 Miatas
Monkeyevil's Avatar
Remember ALL explorer 8.8's are 31 spline. Drum OR disc.
JcrOffroad
Zoom Zoom!
Old November 11th, 2005, 08:56 AM   #4
Kid Rock
8.8 - d44 - d35 axle comparison.
Kid Rock is offline   Reply With Quote
Old November 11th, 2005, 12:48 PM   #5
jeepfreak81
81 inches of fun
Should mention RANGER 8.8's were Drum, 27 spline (IIRC) and i believe narrower... though on this I am not certain... anyone care to confirm?
Page generated in 0.15440 seconds with 38 queries
