360 LA lifter noise help... - Page 2 - Great Lakes 4x4. The largest offroad forum in the Midwest
Old November 13th, 2007, 08:39 AM   #21
Plato2k5
In Da Faaaaaace!!!
Plato2k5's Avatar
This is were things get unclear. I'm not sure how much was shaved off the block as they just cleaned it up. I will have to pull the valve covers off somtime and check.
Is it ok to still drive with the noise or should i stop as it will hurt somthing???
Old November 13th, 2007, 10:01 AM   #22
Enginecraft
Custom engine machining
Enginecraft's Avatar
Noises from a stock type of hydraulic camshaft and valvetrain can't usually be good. Shut it down. . .Cut open the filter first and see if there are any goodies in there just to make sure that the cam didn't eat itself.
Enginecraft is offline   Reply With Quote
Old November 13th, 2007, 09:58 PM   #23
Plato2k5
In Da Faaaaaace!!!
Plato2k5's Avatar
i drained the oil and it had the normal metal shavings in it. Funny thing is, it use to have the noise at low rpm, but after driving it for a while that went away and now its just at higher RPM. I'm just wondering if they havn't pumped up yet?? When the noise went away at low RPM i got more response and power.
Old November 18th, 2007, 03:03 PM   #24
user name
keep your stick onthe ice
user name's Avatar
normal metal shavings?? that tends to be a bad sign.
Old November 21st, 2007, 05:41 AM   #25
Plato2k5
In Da Faaaaaace!!!
Plato2k5's Avatar
i don't mean shavings, just sorta metalic looking
Page generated in 0.16851 seconds with 38 queries
