1 ton YJ - Great Lakes 4x4. The largest offroad forum in the Midwest
Old November 10th, 2007, 09:10 PM   #1
overbuiltyj
overbuiltyj's Avatar
Default 1 ton YJ
I am building a new rig this winter and would like to get rid of my current before I go to far.It is a YJ that runs on propane with a 350,sm465 4 speed(novak adapter),dana 20(1350 yokes and 32 spline output),dana 60 front(5.13s,ARB,35 spline yukon stubs with newer warn lockouts,poisonspyder rockring,poisonspyder hysteer arms with crossover tierod behind axle,AGR ram),dana 70 rear(welded,poisonspyder rockring).Here is a list of some of the stuff it has,New PSC steering box,warn 8274 winch,39 Iroks on homewelded beadlocks,Tom woods driveshafts with 1350 superflex joints and longspline(front is bent but still does the job),bigger Viar compressor,Painless wiring harness,centerforce dual friction clutch with Advanced Adapters hydraulics.It can either have plastic racing buckets or I have a new set of gray vinyl Corbeaus for an extra $350.The front suspension is leaf sprung with RE spring over springs and the rear is coiled and linked with 1.25 heims and RE joints with 2.5x.50 DOM lower links and a wishbone on top.I built this rig 3 years ago with a lot of new parts and have been beating on it and changing it along the way.It needs tore down and cleaned up,for next season,it still works fine but things are loosening up,and the body is wasted.The rig has proved it self over and over again by not pulling cable when others had to.I am looking for $7500 and the only thing I could use in trade is a set of 4 new 42 Iroks,a new PSC double ended hydraulic steering cylinder,and a new PSC steering valve.I will try and get some more resent pics and post,the thing is ugly but the parts are there.If someone is intersted,but does not have time or skills to do the teardown and reassamble,I would do it for some extra $.I won't take anything less than the $7500 unless I delete parts from the jeep and I willl not part it out.Thank you
overbuiltyj is offline   Reply With Quote
Page generated in 0.85523 seconds with 26 queries
