verifying gears - Great Lakes 4x4. The largest offroad forum in the Midwest
Old November 9th, 2007, 08:02 AM   #1
Lothos
KD8GKB
Lothos's Avatar
Default verifying gears
how do I go about verifying gears as being a matched set and what ratio they are outside of the axle of course. I got an install appt, but I want to make sure I have all the necessary parts and the parts are correct.
Old November 9th, 2007, 08:06 AM   #2
gotsand?
sie sehen mich rollin ...
gotsand?'s Avatar
Location: New Era, MI --- "We passed BFE 35 minutes ago."
Send a message via Yahoo to gotsand?
what do you mean? gears are in the box? or in the housing?
in-box: count ring gear and pinion gear teeth and do the math....ring gear/pinion gear = ratio
in axle: spin axle exactly 1 revolution and count the number of times the driveshaft spins...ie. if it spins just under 4 times they are probably 3.92's, 3 3/4 times= 3.73's and so on
edit: probably stamped on housing or in the VIN, but this is the quickest if you dont know what the digits represent
gotsand? is offline   Reply With Quote
Old November 9th, 2007, 08:39 AM   #3
Lothos
KD8GKB
Lothos's Avatar
in box.
Also, is there typically a number of shims, crush sleeves, bearings in an install kit?
Old November 9th, 2007, 08:56 AM   #4
PavementPounder
PavementPounder's Avatar
Look at the edge of the ring gear and find the string of numbers. You will see a pair of numbers sometimes separated by a hyphen, usually near the end of the string. These last two numbers are the number of teeth on the r&p set (like 41-10 = 4.10, see pic below). Do the math on both sets and make sure the ratios are at least within .01 of each other.
Old November 9th, 2007, 08:56 AM   #5
gotsand?
gotsand?'s Avatar
never installed gears before....but the one kit that I got (just needed the shims) did have an assortment of various items.
Old November 9th, 2007, 10:55 AM   #6
PavementPounder
Picture added. The circled symbol is just Precision Gear's ID stamping.
Old November 9th, 2007, 12:39 PM   #7
Lothos
KD8GKB
Lothos's Avatar
Thanks mark. Gonna do that tonight when i get home. I just want to make sure I'm not missing anything.
Old November 9th, 2007, 05:27 PM   #8
KILLER"B"468
Yankabilly
KILLER"B"468's Avatar
The shims in a master kit will vary, but yes depending on the axle there will be a lot. Also as mark pointed out there may be some identification marks. Always make sure it is the gear ratio you ordered. also the will be a number engraved on the pinion head and the ring gear ie: 892, this is to confirm that they have been lapped as a matched set. If there are no identical #'s on the ring gear and pinion ( tooth ratio don't count ie: 41-10 = 4.10) then they are not a matched set.
Old November 10th, 2007, 02:28 PM   #9
Lothos
KD8GKB
Lothos's Avatar
alright, my gear sets are matched so thats good. I'm going to assume the 2 install/bearing kits I got are complete as well since they're still sealed from timken.
Page generated in 0.39328 seconds with 50 queries
