My Yj; 6.0 V8, 700R4, D44, D60, H1's, 37's and OBA - Page 8 - Great Lakes 4x4. The largest offroad forum in the Midwest
Old September 25th, 2009, 09:49 PM   #141
pistol pete
I do vinyl stickers
pistol pete's Avatar
i have a turbo 350 in mine never had a torque converter cover, or the torque bars, i beat on it pretty good and never cracked the housing (its been in there over 7 years,and 13 trips to the badlands and counting) did you have a rubber trans mount? i seen a guy hard mount his to the cross member and watched the trans housing shatter first time out.
pistol pete is offline   Reply With Quote
Old September 25th, 2009, 09:53 PM   #142
Mclovin
"The Situation"
Mclovin's Avatar
Originally Posted by Jeepaholic View Post
So how much dust has collected on this? 1/4"
shit, you're one to talk
Old September 25th, 2009, 10:46 PM   #143
fatboy21
Do it in the mud
fatboy21's Avatar
Send a message via AIM to fatboy21
Originally Posted by Brods View Post
You may want to check with an trans expert like Tranny Tom to see what year cases were the strongest. K case:
Is your torque converter cover thin sheet metal or something heavy? Here are pictures of how GM mounted the 700r4s on the last of the straight axle trucks, is your cover similar?
Its hard to picture a slowly bleeding down jack gently loading the tranny case causing much of a problem, but who knows. Probably a good idea to run with the cover on though.
My dad cracked his bell in his race car and got a Ultrabell. Shits like half inche aluminium. Strong as hell
http://www.campbellenterprises.com/a...ellhousing.htm
fatboy21 is offline   Reply With Quote
Old September 27th, 2009, 12:01 PM   #144
jeepfreak81
81 inches of fun
jeepfreak81's Avatar
Probably the same as all yours.
I agree with you, I did have rubber mount, but it is very coincidental that this happened just a day or two after installing the SYE.
Ultra Bells last I checked were not readily available for the 700R4, they could make me one but it would have been double the price of a TH350 one, and double the price of having someone swap the case for me.
I would work on this more, but with the flatty I really have not had a reason to, that and funds have been short. I'll finish it, I am just not in a hurry to do so.
At least I still have a wheelable rig
Old September 27th, 2009, 12:20 PM   #145
pistol pete
I do vinyl stickers
one other idea, you might want to check and see if you have a bad motor mount if the motor is torquing over more than it should when you mash it ,that could do it as well.
just an idea, your probably right, about the jack sagging, thats a lot of weight hanging off the back of the trans.
Old September 27th, 2009, 12:33 PM   #146
Jeepaholic
Axle Guru Extraordinaire
Jeepaholic's Avatar
Na, cleaned her off. Besides yours has been apart longer. And I work on mine once in a great while
I am going to start charging interest on that axle you still haven't touched
Mclovin get a fucking life loser, some people have more important things to spend time on like a family
Old September 28th, 2009, 11:30 AM   #147
jeepfreak81
81 inches of fun
Motor mounts are good
The YJ has been down 2.5 years, and I work 45-65 hours a week in the summer. I just don't have time right now, or the extra cash for that matter especially since my wife is going for her masters now. Do you think I enjoy looking at it sitting there? I'm not going to skip bills to fix a jeep that isn't a DD though.
If you need the axle from under the flatty, I'll pull it into the portable garage and cut the old one out, or you can pick up yours. I just have not had time to do it, and have not really wanted to yet because EVERY swap we have done on either jeep has gone way over budget and time, I have not been driving it anyway because I have not even had time to pull the oil pan and fix it in 2 months.
BTW do you need a jeep 231 case too or just the 231C internals? I know I have some 231C cases. I have not found the jeep ones though as I have not been to my dads.
Old September 28th, 2009, 12:34 PM   #148
Jeepaholic
Jeepaholic's Avatar
I know just hairyassing you, same reason mine isn't done.
Na, it would be nice to take it to the swap meet though as some extra $$ would be nice.
Well I would like; the parts for a wide chain and I think the 231c has the better planteary? So guts from a 231c and if you have any J parts my brother needs one
I need to come over and check out the sweet Ford though
Old September 28th, 2009, 12:34 PM   #149
Mclovin
"The Situation"
Mclovin's Avatar
wow... did i strike a tough guy nerve ?
Old March 30th, 2010, 10:02 PM   #150
jeepfreak81
81 inches of fun
Front axle and Transmission were dropped off at Allpro Automotive in Lansing tonight. I have heard nothing but good about Ken, and he supports the sport. http://www.apalansing.com/
Once they are back, some reassembly and look for a rear drive shaft and I should be able to go for a spin
Edit: How sad is it that I just went back and looked at the dates. It was exactly a year ago to the day that that transmission and axle were pulled to take to Allpro and I just did it...
At this rate I will get my seats back in and driveshaft mounted by the rumored apocalypse in 2012....
Old March 30th, 2010, 10:16 PM   #151
somer1
You Get the Big One
somer1's Avatar
The 231c HD is the one your refering to and has the same 6 pinion planetary that many after market cases use plus an 1.25" chain over the 1.0" chain found in 231j's and some light duty 231's if it's an hd it will say right on the tag on the back of the transfercase.
somer1 is offline   Reply With Quote
Old March 30th, 2010, 10:40 PM   #152
jeepfreak81
81 inches of fun
WTF are you talking about. I know I have a 231C I also know what guts are in it as I have had and torn apart 3 of them
Old April 5th, 2010, 08:50 PM   #153
jeepfreak81
81 inches of fun
Got most of the floor pan out. I should have the trans and axle back this week if there are no hitches.
Out with the old...
In with the new...
Old April 5th, 2010, 09:07 PM   #154
suckyjunk
suckyjunk's Avatar
Jacob, when do you plan on welding your new floor pan? I need to fresh'n up on how to fab skills.
suckyjunk is offline   Reply With Quote
Old April 5th, 2010, 09:25 PM   #155
jeepfreak81
81 inches of fun
I probably will be in the garage all weekend. The wife is going out of town and I should have my tranny and axle back this week :fingers crossed: Whether I get to the floor pan though I do not know. My goal is to have it back on it's wheels and the front shaft hooked up so I can move it. That and measure for a new rear shaft.
Old April 6th, 2010, 09:09 AM   #156
Jeepaholic
Jeepaholic's Avatar
You want some help?
Old April 6th, 2010, 09:19 AM   #157
jeepfreak81
81 inches of fun
You want some help?
If you can get away I am sure I could use some. I don't have all the rear brake parts yet. I am trying to decide what is priority, lose the drums, a new shifter, or sport cage.
Old April 6th, 2010, 09:26 AM   #158
Jeepaholic
Jeepaholic's Avatar
I will see what I can do
Old April 6th, 2010, 11:37 PM   #159
suckyjunk
suckyjunk's Avatar
1. Cage
2. -Drums
3. Shifter
just my .02 cents
Old April 7th, 2010, 07:53 AM   #160
jeepfreak81
81 inches of fun
1. Cage
2. -Drums
3. Shifter
just my .02 cents
That would be the case, but I don't have even close to the $$ for a sport cage right now Otherwise I would agree.
Page generated in 0.38448 seconds with 84 queries
