My Yj; 6.0 V8, 700R4, D44, D60, H1's, 37's and OBA - Page 10 - Great Lakes 4x4. The largest offroad forum in the Midwest
Old November 28th, 2011, 08:19 PM   #181
tw1st3d5
tw1st3d5's Avatar
Originally Posted by Mclovin View Post
yea the plates are made of cast iron.. there are many cases of them cracking down the middle.. Im not sure which co. it is but someone on pirate under the venders makes them out of a better metal..
That would be Swag Offroad I believe. Lots of DIY stuff from them.
http://www.swagoffroad.com/Arbor_Press_Plates.html
Old December 5th, 2011, 09:10 PM   #182
jeepfreak81
81 inches of fun
jeepfreak81's Avatar
Front brakes hooked up and everything works. I will do the line lock if I have time. I need to reattach the lines to the frame now.
Old December 8th, 2011, 04:56 PM   #183
jeepfreak81
81 inches of fun
Found the left front caliper leaking today, I hope I got it sealed up now. I am scared to torque on the banjo bolt any more than I have.
The new U-joint to get the steering shaft in proper working order came, so I have parts to install.
It RUNS! Even on 3 year old skunky gas.
http://smg.photobucket.com/albums/v4...=VIDEO0001.mp4
Old December 11th, 2011, 11:02 PM   #184
jeepfreak81
81 inches of fun
OK Apparently I have no clue what the shaft size of my Steering box is. 2nd U-joint came for the input shaft and it doesn't fit either. I thought it was a 3/4" 30 or 36 spline, but neither fits. Looks like I have to send yet another one back. They are both too small.
Adam stopped by and we got more stuff done...
New front shackles
One new rear shackle
The other... ugh.
We also got the new Lokar shifter in, and Adam fixed/modified my t-case shifter to be a LOT nicer.
Cleaned out 'the shed' as Adam has come to call it.
Old June 21st, 2012, 03:28 PM   #185
Jeepaholic
Axle Guru Extraordinaire
Jeepaholic's Avatar
Well it has been the 4 month gap on working on it so lets do some wrenching
Old May 17th, 2013, 09:10 PM   #186
Jeepaholic
Jeepaholic's Avatar
This needs it's yearly bump
Hopefully I will get my hands on this in a week or two and finally complete the build
Old November 25th, 2013, 10:54 PM   #187
jeepfreak81
81 inches of fun
Well it made it to the new shop without being parted out or sold... maybe I can finish it now with more room. Just need motivation.
Old November 27th, 2013, 08:57 PM   #188
Tie Dyed
O.G.
Tie Dyed's Avatar
Send a message via AIM to Tie Dyed
I will buy it with out the engine/trans. I need a new YJ.
2000 XJ with a 3 inch body lift
Tie Dyed is offline   Reply With Quote
Old April 28th, 2014, 12:09 AM   #189
Jeepaholic
Jeepaholic's Avatar
Over 2 yrs later we finally got the shackles finished and a few other odds today
Old April 28th, 2014, 09:22 AM   #190
jeepfreak81
81 inches of fun
Yep, back to work. Much easier with a shop you can move in and find tools when you need them
New bushings in the frame and shackles
New steering shaft installed
Lock outs finally installed. Took forever because the stub shaft had to be removed because it was hitting a ball joint grease zerk making it off center. Glad to find out about it now.
To do:
Re-plumb transmission
Weld in floor board
Weld in patch under the jeep embossment
Rebuild rear driveshaft
Bolt up torque converter
Clean up what ever other messes we find (likely mostly electrical)
Old April 30th, 2014, 05:46 PM   #191
Gunsworth
Gunsworth's Avatar
Kudos! Still need to button up the engine swap in mine. We have to be some of the longest standing yj owners on here
Old October 25th, 2014, 05:06 PM   #192
jeepfreak81
81 inches of fun
Got somewhat motivated today and Adam came and helped
Sent from my HTC6525LVW using Tapatalk
Old October 26th, 2014, 08:10 PM   #193
jeepfreak81
81 inches of fun
Got some more done tonight
Old October 26th, 2014, 08:39 PM   #194
Jeepaholic
Jeepaholic's Avatar
Goal is driveable by Snowfari, and wheelable by next year. I have said that before though.
I would love to have it for Snowfari, but would be scared to have that be a shake down run.
Hopefully will this coming one knock on wood
Old October 26th, 2014, 09:59 PM   #195
jeepfreak81
81 inches of fun
You really want heat for once don't you
Old October 26th, 2014, 11:25 PM   #196
Jeepaholic
Jeepaholic's Avatar
And not bouncing off the hard top when you hit shit lol
Old October 27th, 2014, 09:54 AM   #197
jeepfreak81
81 inches of fun
Well buckle your seat belt silly, that's why we put them in.
Old November 12th, 2014, 01:01 AM   #198
jeepfreak81
81 inches of fun
Mounted the transmission and air lines
Also turned it over for the first time in a long while
Hopefully moving soon.
Sent from my SM-G900V using Tapatalk
Old December 7th, 2014, 06:06 PM   #199
Jeepaholic
Jeepaholic's Avatar
Needs updates @jeepfreak81
Old December 7th, 2014, 08:55 PM   #200
jeepfreak81
81 inches of fun
Patience the huge video took awhile to upload.
Fuel lines hooked up, trans lines had a small leak
Shocks on front welded up
Running like it was just parked yesterday
1994 Wrangler YJ resurrected:
Page generated in 0.55475 seconds with 85 queries
