DIY: OnBoard Welder (OBW) - Page 2 - Great Lakes 4x4. The largest offroad forum in the Midwest
Old November 8th, 2007, 11:19 AM   #21
brimy311
Smells like a Fork Liftis
brimy311's Avatar
Originally Posted by victorymike View Post
You mentioned making just the box...I'd be interested in that for sure. Then all I'd need is the cables and manual throttle. You got me fired up on my project again. Thanks!
Let us know how much you'd like for the box so I can get it together and send you some $.
To build a control panel, fully wired (you would just need to run the trigger to 12v and to the alt and hook up the cables from the alternator) it would be $125.
JcrOffroad.com
Like us on Faceook!
Old November 8th, 2007, 11:38 AM   #22
itselliott
itselliott's Avatar
Super write up!...............Should be a permanant stickey in the tech forum!
Old November 8th, 2007, 12:22 PM   #23
BMFmike
meh.
BMFmike's Avatar
Not bad for the person that touches a dead wire and gets shocked.
Old November 8th, 2007, 01:57 PM   #24
jared
Can't Worry About It
jared's Avatar
have you tested out the outlets yet? or is it an ac alternator.
my understanding would be that a normal alt. is a/c current but is rectified to dc using the six diodes in the alternator. so your outlets would have power, but only dc power and not a/c current and 60 hz that any standard electrical device uses.
maybe i am overlooking something
jared is offline   Reply With Quote
Old November 8th, 2007, 02:09 PM   #25
deuce228
Redneck Poser
deuce228's Avatar
Yes you are. He already addressed it.
Only works with brushed motors.
Old November 8th, 2007, 02:32 PM   #26
brimy311
brimy311's Avatar
I also thought that the Alt would put out AC voltage, but once I tested it with a voltmeter it would not ready any AC voltage. It will only read DC voltage. So you actually are geting 110v of DC voltage. This is the reason why you can only run Brush driven type AC motors. Ie: Drills, and Grinders.
JcrOffroad.com
Like us on Faceook!
Old November 8th, 2007, 03:11 PM   #27
victorymike
Geocache Addict
victorymike's Avatar
Could you please PM me your address and name so I can send you $125 for that control box? That is really worth it to me. It looks fantastic! Will a money order be okay?
victorymike is offline   Reply With Quote
Old November 8th, 2007, 03:37 PM   #28
KartRacer
Blowd up
KartRacer's Avatar
Don't forget to mention the Dewalt grinder brushes.
Old November 8th, 2007, 05:18 PM   #29
brimy311
brimy311's Avatar
Just to help explain a few of the weird posts:
Don't do this:
I was having a hard time getting the voltage, it was mostly because I was using the voltmeter to look for AC voltage. I thought maybe that there was an internal regulartor screwing me. I pulled it apart to find nothing.
While re-assembling this alternator, I must have not got the back brush in correctly. It took a crap at flat nasty and would no longer put out any voltage. We stole a brush from kart racers grinder and made a spring out of mechanics wire. It worked for about 5 minutes and then died I went and picked up a new alternator today and installed it. Everything works great.
So, don't tear it apart! lol. If it is a Big case Ford Alternator. It will not be internally regularted at all.
JcrOffroad.com
Like us on Faceook!
Old November 8th, 2007, 05:18 PM   #30
Sandals
Fucking Zen as Shit
Sandals's Avatar
hahaha, nice....
I have one 90% completed, just need to mount the alternator and the box.
Looks good though, and better weld than I would have expected
Old November 8th, 2007, 05:51 PM   #31
toolmantim
Go lil yellow Roobicon...
toolmantim's Avatar
Yep. The 70's Chryslers used mostly externally regulated alternators also. The housing looks like a cage. Mounting options can suck with these though.
Great write up.
I can see the paper clip, how could you not put it back together properly???:tonka:
I'm compensating for my manhood.
Northwest Ohio Crawlers
toolmantim is offline   Reply With Quote
Old November 9th, 2007, 02:05 PM   #32
TopHeavy
Yikes!
TopHeavy's Avatar
Good write-up.
Buy My CJ7
TopHeavy is offline   Reply With Quote
Old November 9th, 2007, 02:28 PM   #33
thormxboy420
FOUNDRY RATT
thormxboy420's Avatar
Send a message via AIM to thormxboy420
great job man, good work
thormxboy420 is offline   Reply With Quote
Old November 10th, 2007, 01:56 PM   #34
jared
jared's Avatar
well it would put out 3 phase a/c voltage if you removed the diode pack form it, but then the frequency of it would vary with rpm, and would be useless
i see onlu brush type motors now. thanks for the reply back
Old November 10th, 2007, 09:20 PM   #35
brimy311
brimy311's Avatar
i see only brush type motors now. thanks for the reply back
There is No diode pack in this alternator. It is an Externally regulated alternator, so if you don't have the regulator hooked up you can get max voltage out of the alternator. No alternator puts out any form of AC voltage, because in order to get AC voltage you would need a motor with two windings.
JcrOffroad.com
Like us on Faceook!
Old November 10th, 2007, 09:46 PM   #36
landrollover
landrollover's Avatar
Send a message via AIM to landrollover
The rectifier is what changes the current from ac to dc, your ford alternator has one. Its the part under the stator windings in your picture.
Rectifier operation
landrollover is offline   Reply With Quote
Old November 11th, 2007, 08:40 AM   #37
brimy311
brimy311's Avatar
hmmm, weird. I was totally misunderstanding the inside of this thing.
I found this PDF this morning: Autoshop 101 understanding the Alternator:
http://www.autoshop101.com/forms/alt_bwoh.pdf
Good read. Clears up alot.
JcrOffroad.com
Like us on Faceook!
Old November 11th, 2007, 02:50 PM   #38
victorymike
Geocache Addict
Yeah...rectified...not regulated. That is what I read.
Old November 15th, 2007, 09:09 PM   #39
David
Maybe a dumb question, but is it possible to weld on your own vehicle? Or will it cause problems? I have seen welders that you can and can't weld on your own vehicle. Just wondering, and again thank you for all of this information.
David
PLease, does anybody know this? I got mine built and works nice, but I would like to know if I can weld on my own before I try it.
David is offline   Reply With Quote
Old February 17th, 2008, 11:34 AM   #40
firehawk
Live Action!
firehawk's Avatar
Have you thought of putting a smaller pulley on the alternator? That way you would not have to rev the motor so high.
Page generated in 0.37316 seconds with 83 queries
