DIY: OnBoard Welder (OBW) - Great Lakes 4x4. The largest offroad forum in the Midwest
Old November 7th, 2007, 04:41 PM   #1
brimy311
Smells like a Fork Liftis
brimy311's Avatar
Default DIY: OnBoard Welder (OBW)
Looking to be able to weld on the trail? No looking to spend $1200 on a Mobiarc or preimer welder? Here is the answer. A homebrewed stand alone OnBoard welder.
You want to use an alternator that is 80amps or larger. I used a 100amp Ford Large Case Alternator. You want the alternator to be Externally regulated so that you don't have to modify the alternator to make it a weldernator.
The Alt I used was from like a mid 70's ford. The part number is GNC 7705-12. It cost about $90 new from a our local parts joint.
On my motor, I have a York compressor already mounted. I was able to use the other side of the york for the bottom mount:
This the upper mount that I made:
I ended up slotting the top hole to all for some more adjustment. I might end up remaking it to have some more adjustment.
Now, I really wanted a nice clean Control Panel/ Control box for this welder and could not find much online that I liked. I found the plastic box at Radio Shack. It was like $8 for it.
I used 2 toggles; 1 to turn on the welder, the other to turn on the outlets. The light is to signal when the welder is on. The two fuse holders on top are holding 30a fuses. The top one is for the outlets and the lower one is for the welder trigger.
I purchased the Panel Meter from China. Found it on ebay. You can get them for about $25. The guage reads from 0-200v's. You can find ones that will ready 0-150v's as well.
The last two things on the box are the + and - plug in's for the welding leads. I need to mark them better, but currently I have the right one for + and the left for -.
I purchased all the welding stuff from our local welding supply shop. It cost about $200 for the wire, rod, rod holder, ect.
Wiring Diagram:
Positive lead, 20 feet:
Negative lead, 20 feet:
3/32" rod 6011 and holder:
The welder is not strong enough to burn 1/8" rod, so you must use 3/32".
Purchased this bag from Youngs Army Navy for $9.
Did not like the idea of working under the hood without a guard on the alternator fins:
The inside wiring of the box:
System hooked up and on:
Cleaned weld:
On the trail use:
The entire cost of the project was about $375 + about 2 days of my time. I could probably build this setup for others installed for about $700. I could also build the control panels for those that need just that made.
I will put together a wiring diagram tomarrow and I will also get some pics of the hand throttle and some other things.
JcrOffroad.com
Like us on Faceook!
Old November 7th, 2007, 04:47 PM   #2
PavementPounder
PavementPounder's Avatar
Originally Posted by brimy311 View Post
Is that Blackbeast2 holding for you and looking directly at the weld?
Old November 7th, 2007, 04:47 PM   #3
RDK_YJ88
Never Lift
RDK_YJ88's Avatar
great write up! lot-ah-info
Old November 7th, 2007, 04:47 PM   #4
Shotgun
I only wheel with boats.
Shotgun's Avatar
thats a sweet setup
Old November 7th, 2007, 05:03 PM   #5
victorymike
Geocache Addict
victorymike's Avatar
I'd love to see the hookup of the wires on the back of the alternator. Field, + and -. I have had a weldernator project on my back burner for a year now and already have an externally regulated alternator from a '76 Ford motorhome (I think...got specs at home and am at work now). I made an adjustable bracket to mount it in the same spot you have. Need a combo serp/v-belt alternator pulley to spin it tho. That control box you have is totally awesome. You mentioned making just the box...I'd be interested in that for sure. Then all I'd need is the cables and manual throttle. You got me fired up on my project again. Thanks!
Let us know how much you'd like for the box so I can get it together and send you some $.
victorymike is offline   Reply With Quote
Old November 7th, 2007, 05:20 PM   #6
BMFmike
meh.
BMFmike's Avatar
Awesome work.
Old November 7th, 2007, 05:48 PM   #7
victorymike
Geocache Addict
I understand that if you use the hand throttle to dial in 115 volts DC on your guage that you can use those outlets to power any type of electrical device with brushes...like grinders and drills and such. Is this correct?
Old November 7th, 2007, 06:59 PM   #8
OnlyInMyXJ22
No Money = No Fun
OnlyInMyXJ22's Avatar
That is sweet!!
*2007 Rubicon
*2006 Duramax
Old November 7th, 2007, 07:07 PM   #9
cvwindows
I think I can make it!!!!
cvwindows's Avatar
Wow cool post. Is it possible to use a ready welder with a system like this so you dont have to use two batteries?
cvwindows is offline   Reply With Quote
Old November 7th, 2007, 07:09 PM   #10
brimy311
brimy311's Avatar
Yah you can run only brush type AC motors. The Voltage output from this is actually high frequency DC not AC.
Let me crunch some numbers on the control box and get back to you on that.
If you were to use crappier welding leads you could probably do this project cheaper. However you will lose voltage to the arc with crappy stringer or ground.
JcrOffroad.com
Like us on Faceook!
Old November 7th, 2007, 07:14 PM   #11
David
That is a really good idea, I can't wait for the pics. Thanks for the info.
David.
David is offline   Reply With Quote
Old November 7th, 2007, 11:39 PM   #12
brimy311
brimy311's Avatar
The Ready welder I believe runs on 24v or like 18v. I am not sure if you can run it off of this or not. that would be a question for the ppl at ready welder.
JcrOffroad.com
Like us on Faceook!
Old November 8th, 2007, 07:38 AM   #13
shawn
Resident HVAC/R Jambi
shawn's Avatar
Sweet job man! I am feeling motivated to do this now.
Old November 8th, 2007, 07:44 AM   #14
cvwindows
cvwindows's Avatar
Yeah I will check. It sure would be awsome not to have to pull batteries everytime were out on the trail welding and have a wire feed gun. What is the highest volts you think your getting out of the alt?
Old November 8th, 2007, 08:18 AM   #15
brimy311
brimy311's Avatar
I am not sure, I know for a fact that it will run up to about 115v. It is running at like 3500 rpms at that point. I will have to check and see what the max voltage would be.
JcrOffroad.com
Like us on Faceook!
Old November 8th, 2007, 08:21 AM   #16
cvwindows
cvwindows's Avatar
I looked on premier power welder site and they say you can run one but dont say how. I will have to check with them.
Old November 8th, 2007, 10:03 AM   #17
brimy311
brimy311's Avatar
I added the wiring diagram above. I will get some more pics this afternoon.
JcrOffroad.com
Like us on Faceook!
Old November 8th, 2007, 10:38 AM   #18
Stan
I got a gold chain
Stan's Avatar
Maybe you should add a working alt.
Stan is offline   Reply With Quote
Old November 8th, 2007, 10:41 AM   #19
Icebreaker88
Icebreaker88's Avatar
Is this a 2nd alt or are you using it as your primary alt also?
[QUOTE=TurdBronco;1095911]I don't usually race cause it is still a focus.[/QUOTE]
Icebreaker88 is offline   Reply With Quote
Old November 8th, 2007, 11:15 AM   #20
brimy311
brimy311's Avatar
This is a second stand alone alternator. That way if you burn it up, you can still drive your own vehicle without issues.
JcrOffroad.com
Like us on Faceook!
Page generated in 0.46854 seconds with 83 queries
