Restored CJ7 trail / rock Jeep - Great Lakes 4x4. The largest offroad forum in the Midwest
Old November 7th, 2007, 12:01 PM   #1
amc78cj7
amc78cj7's Avatar
Default Restored CJ7 trail / rock Jeep
Reposting since the last thread got filled with from others. Rust-free. Taking up valuable space in my tiny garage.
$12,000 you get the CJ with new Synkro seats and a 18' dovetail dual axle trailer with new deck and new electric brakes.
$10,000 Jeep alone.
A cousin of mine professionally hauls cars and can take it anywhere for $500. Or I'm heading to Michigan in December and can bring it with me if the transaction is done before hand (I'm not driving it up in December just to tow it back down again).
Titled as a 1978 CJ7. It has had a very easy life with a lot of sheltered garage time.
I did a frame off a year or so ago when the Jeep had only 65k miles. Only been on three wheeling trips since the rebuild.
4WD hardware Fiberglass body
Hinged front fenders
LED tail-lights, recessed
Sandblasted and POR-15'd frame. Extended shock mounts on all four corners
Full roll cage (covers entire seating area, front and rear) tied into frame
custom rock sliders also welded to frame
Swingout bumper / tire carrier
Fresh-built Throttle body injected Chevy 350 V8. Comp Cam. Flat Piston. Dual exhaust.
flex-a-lite black magic electric fan
aluminum radiator
Centech wiring harness
700r4 tranny (built by KillerB)
B&M megashifter
NP241c t-case with JB conversions slip-yoke eliminator
Borgeson Heavy Duty steering shaft
Full width high pinion kingpin Dana 60 front with heim high-steer, dual piston caliper disc brakes 5.13 gears
Full width full float D60 rear with disc brakes and detroit locker 5.13 gears
(Front and rear gears installed by KillerB)
Tom woods CV rear driveshaftAnn Arbor Driveshaft front driveshaft
dual optima batteries (one red, one yellow)
Warn XD9000i winch
(5) 38x15.5x17LT Super Swamper Radials (95% tread, almost new) on 8 lug aluminum rims
MORE Boomerang shackles
Spring Over Axle with Wagoneer front leafs on all corners (about 8-10" lift and super flexy).
Factory fiberglass Hardtop + safari bikini top
Full steel doors (late CJ model with paddle handles)
Two-piece soft doors also with paddle handles
New Hunsaker Synkro Suspension seats with Edge Engineering brackets
I'm sure there are other parts I am forgetting about, but that is pretty close to everything. Also pre-wired to be flat-towed and use the vehicles lighting system.
I'm not quoting idiots who promote unsafe recovery strap techniques anymore. :miff:
amc78cj7 is offline   Reply With Quote
Old December 16th, 2007, 06:34 PM   #2
cjmatt
cjmatt's Avatar
any trades? Ill give ya a low mileage Grand National for it
cjmatt is offline   Reply With Quote
Page generated in 0.25106 seconds with 29 queries
