99 suburban 6.5 diesel - Great Lakes 4x4. The largest offroad forum in the Midwest
Old November 6th, 2007, 10:48 PM   #1
rriggs55
Default 99 suburban 6.5 diesel
I'm considering a 99 6.5 diesle w/ 135,000 miles, and using it to pull a 9,000 lb camper. How is it for dependability and for towing this weight. I had a friend who towed our 13,000 lb sailboat w/ a suburban 1500, so it would stand to reason that I should be able to tow a 9,000 camper.
Any advice before I spend the money. It's mint and they're only asking $4g's.
rriggs55 is offline   Reply With Quote
Old November 6th, 2007, 11:28 PM   #2
Roadhouse
DrivewayJeeper
Roadhouse's Avatar
A 6.5L in a 99 is a rare. It should tow just fine....rear springs will sag pretty bad, and the tranny will be worked hard.
Funny thing is the 1500 w/6.5L TD is rated to tow less than a 1500 w/5.7L vortec.
$4 for that is a good deal...I've seen people as 10K for '99s with a 5.7L
Old November 7th, 2007, 09:01 AM   #3
rriggs55
Maybe I'd be better off w/ a Ford F250 diesel for $5,500 - same mileage??
Old November 7th, 2007, 03:32 PM   #4
cronus
cronus's Avatar
It depends on the details, if itís a 2500 sub with 4.10 gears you might be ok, if itís a 1500 with 3.42 gears no fín way. This link has the tow ratings for the 6.5ís http://www.dieselplace.com/forum/sho...d.php?t=180449.
cronus is offline   Reply With Quote
Old November 7th, 2007, 05:39 PM   #5
Bones
Bones's Avatar
a Ford 7.3L powerstroke will always be more reliable, pull more, and get better mileage than a 6.5L
Inviscid Motorsports
Motorcity Machines
Branik Motorsports
Maxxis Tires
Raceline Wheels
PAC Racing Springs
Joint Clutch and Gear
Old November 7th, 2007, 05:46 PM   #6
Freak
Wheelin the HD
Freak's Avatar
find yourself something with a cumins and pull anything and everything but I'm biased and tow around 18,000 lbs with my Ram 3500
Old November 7th, 2007, 06:49 PM   #7
Roadhouse
DrivewayJeeper
Roadhouse's Avatar
6.5TD can get some good mileage...better in a truck than a Sub....but yes the Powerstroke is a far better motor.
Old November 7th, 2007, 07:31 PM   #8
twodollars
twodollars's Avatar
I have a 95 3/4 ton 4x4 burb with a warmed over 6.5. It tows fine for me, and with 3.73 gears I can get a little over 20 mpg on the highway.
twodollars is offline   Reply With Quote
Page generated in 0.28691 seconds with 47 queries
