Dodge track bars... - Great Lakes 4x4. The largest offroad forum in the Midwest
Old November 6th, 2007, 08:36 AM   #1
Monkeyevil
I <3 Miatas
Monkeyevil's Avatar
Default Dodge track bars...
School me... Stan said he has ran through a few moogs. My truck was all over the road this weekend after new tires, a new draglink and ball joints.
Anyone have a beefy after market one? I guess I could build one as well...
JcrOffroad
Zoom Zoom!
Old November 6th, 2007, 08:44 AM   #2
silverxj
Recovering XJ owner
silverxj's Avatar
I went through 2 cheapy XRF's before getting a Moog. I've had good luck so far, but still feel it wandering ... I've also replaced balljoints, wheel bearings, complete steering and adj the steering gear.
I would say make your own ... or Moog's are lifetime, so either way...
Old November 6th, 2007, 12:02 PM   #3
bigjeep65
Lurker
bigjeep65's Avatar
Stock or leveling kit, 4x4, year?
There is a steering box brace that PP was looking into in Dodge tech. Supposed to help considerably with steering wander. Also a replacement trackbar, adjustable to keep the axle centered
For 2nd gen trucks, there is also a steering upgrade using stock '98 pieces (better design, bolt in).
bigjeep65 is offline   Reply With Quote
Old November 6th, 2007, 12:11 PM   #4
bigjeep65
Lurker
bigjeep65's Avatar
Sometimes I wonder what I'm thinking. Found the correct thread, it's Ram v4.5 in rig builds. Page 3.
Yeah, I know, learn how to post a link
Old November 6th, 2007, 05:12 PM   #5
PavementPounder
PavementPounder's Avatar
I highly recommend the steering box brace. The difference was noticeable and immediate. Only took a half hour, is serviceable, and I see it on Rams on other custom fab shop sites.
Here's the link to the brace:
http://www.solidsteel.biz/dss.htm
As for the track bar, I ran Moogs for years and ran though a few. However, I found that "a few" with a lifetime warranty was acceptable over the course of 160k+. What makes the biggest difference is changing out your upper mount, which I have also done.
Here's a bracket they make that allows you to use the newer-style track bar:
http://www.solidsteel.biz/tbk.htm
My Skyjacker lift came with a bracket that does this. It has not loosened or wore out, but the poly bushing at the lower end has been replaced and needs to be replaced again. I would not expect your truck to go through them like mine has.
There is another company that people on Pirate seem to like a lot. I bookmarked them at home and can't remember the name. They make beefy track bars, but they are also one of the sites where I saw the Solid Steel box brace fitted to most fo the rigs pictured.
Old November 6th, 2007, 05:23 PM   #6
nixxerRsixxer
Homewrecker
nixxerRsixxer's Avatar
Thuren Fabrication makes an Aftermarket TB, I used to have a DT Pro Fab however they appear to be no longer in business.
nixxerRsixxer is offline   Reply With Quote
Old November 15th, 2007, 01:46 AM   #7
merr6267
More boost than yours:)
merr6267's Avatar
I have a Thuren in the mail right now . . .
We'll see.
merr6267 is offline   Reply With Quote
Old November 15th, 2007, 10:19 PM   #8
rm25x
rm25x's Avatar
Thuren is the one it seems everyone swears by on Pavement Sucks and Pirate.
rm25x is offline   Reply With Quote
Old November 15th, 2007, 11:13 PM   #9
merr6267
merr6267's Avatar
I forgot to mention, I also have the Solid steel brace that PP posted about earlier. It seemed to take out a good bit of wander . . . it was hard for me to tell though as my track bar has been pretty bad the whole time I had the brace.
Even if I had a perfectly healthy steering system I think the SS brace is a good investment. It puts the sector shaft in a double-shear loading situation, which is much better than a single bearing loaded by a long lever . . . and the support bearings are pretty cheap.
I thought about building something like it for my Jeep, but then I realized that if I build a rig for rocks/trails etc. I'll probably go with a hydraulic setup anyway.
Take care,
Phill
Old November 17th, 2007, 12:27 PM   #10
user name
keep your stick onthe ice
user name's Avatar
I always use Moog when I replace them. IMO moog has the best hassle free warranty and Rams really like to wear out trackbars so you'll probably end up getting more than one put on.
Old December 4th, 2007, 12:32 AM   #11
Cartman
Can't lose with 42s
Cartman's Avatar
I've got the DSS and it rocks. Helped my steering wander big times. My trackbar is hit up and it only has 30K on it, was desperate and out of town so I had to buy a napa lifetimer...
I'm doing 4.5" SJ coils 2" spacer, RK long arms and Thuren's adjustable trackbar..my fingers are crossed!
I've also redone my steering to the updated inverted T (or Y cant' remember) 98 "HD" stuff, much much beefier than the stock stuff. This is on a 2500, might not help the half ton guys much..
Cartman is offline   Reply With Quote
Old December 20th, 2007, 01:42 PM   #12
Screaminhillbilly
Scott
Screaminhillbilly's Avatar
Clyde's Frame and wheel in Pontiac has a fix for the track bars. They weld an assembly on to it that takes the place of the nylon preload ring. The preload ring is usually what fails. After this is done preload is adjustable and there is not a nylon ring to fail. I had this done to my track bar two and a half years ago and have not had any issues since.
Screaminhillbilly is offline   Reply With Quote
Old December 20th, 2007, 01:53 PM   #13
PavementPounder
Are you saying that they remove the lower mounting bushing?
Old December 20th, 2007, 02:03 PM   #14
Screaminhillbilly
Scott
No, they remove the nylon preload ring in the upper ball/ socket assembly. It is replaced with a forged brass piece. There is an adjustable setscrew with a spring plate that provides the preload onto the brass piece.
I went through five track bars before this. When we disassembled it to add this fix the nylon ring was cracked.
Old December 20th, 2007, 02:06 PM   #15
PavementPounder
Okay, so it still attaches to the factory bracket on the frame in a vertical manner?
Old December 20th, 2007, 02:10 PM   #16
Screaminhillbilly
Scott
Thats correct.
Old December 20th, 2007, 02:26 PM   #17
PavementPounder
Okay, I think I'm following this, but it would help if you happened to have a picture. You have a non-adjustible track bar with a brass bushing at the upper end attached to the factory upper mount?
Old December 20th, 2007, 08:27 PM   #18
Screaminhillbilly
Scott
yes.
Unfortunately I am not able to get a pic right now.
Basically it is a modification to a stock track bar which solves the design flaw that causes them to fail in the first place. Furthermore, the fix allows adjustment of the preload on the ball socket assembly.
Old December 21st, 2007, 12:17 AM   #19
Monkeyevil
I <3 Miatas
Monkeyevil's Avatar
I am going to build my own with a 1-ton TRE. Will see how long it lasts.
JcrOffroad
Zoom Zoom!
Old December 24th, 2007, 09:29 PM   #20
bigtruckman
One shot, One Kill
bigtruckman's Avatar
I think this is what a friend mine did to his and said it works good.
http://ramchargercentral.com/index.p...owtoshow;id=79
bigtruckman is offline   Reply With Quote
Page generated in 0.76428 seconds with 83 queries
