Super chargers and Turbo's - Great Lakes 4x4. The largest offroad forum in the Midwest
Old November 5th, 2007, 07:31 PM   #1
Blackbeast2
Hardcore since 84
Default Super chargers and Turbo's
Hello all,
Im really dont know that much about superchargers and turbos other then installing a few. I really want to install a super charger in my ford. CVPI 4.6L. But im not totually against setting up a turbo system. Im Building a sleeper. Its all ready fast as hell. Anyway after a few search's I havnt really came across much. Any one out there have any exp. with a certin brand over another. I was looking to spend no more then 2k. As I have seen them range everwere from 1200-5000.
No nos engine has to many miles for me to want to use spray on it.
Thanks
Blackbeast2 is offline   Reply With Quote
Old November 5th, 2007, 07:36 PM   #2
Dieselphreak2000
Somehow still alive..
Dieselphreak2000's Avatar
S/C won't be much better if you're that worried about the engine. Unless you run a smallish level of boost. Or replace the headgaskets with quality ones, and then you're set. My Tbird SC is running a 10% OD on the blower pulley, and no problems after 100k miles, i attribute that to the nice ROL gaskets.
Dieselphreak2000 is offline   Reply With Quote
Old November 5th, 2007, 07:43 PM   #3
GreaseMonkey
Pew pew!
GreaseMonkey's Avatar
Ever hear of the Ford Tech or General Tech forum?
Old November 5th, 2007, 08:26 PM   #4
Blackbeast2
Hardcore since 84
Thanks you for not helping at all greasemoney....I could not rest easy tonight with out your great answers...
Old November 5th, 2007, 10:39 PM   #5
GreaseMonkey
Pew pew!
I helped. I directed you towards the proper forum to post in next time.
Old November 5th, 2007, 10:47 PM   #6
Toivo
Feel lucky?
Toivo's Avatar
Yes, Im sure the great Blackbeast has installed multiple turbos and superchargers on hundreds of vehicles.
He also invented the Detroit Diesel. And gravity.
Old November 6th, 2007, 12:10 AM   #7
gofastbobby
The guy Dale doesn't know
gofastbobby's Avatar
good luck finding a s/c for less than 2k thats worth a shit...imo, do it right the first time. fwiw i have heard good things about procharger, vortech, and kenne bell...but they are way out of your price range. maybe you could find a used one somewhere.
gofastbobby is offline   Reply With Quote
Old November 9th, 2007, 12:16 PM   #8
EERNGER98
Taco driving jeep wheeler
EERNGER98's Avatar
Ya in that price range your going to have to go looking for a used turbo or s-charger. however this brings up a problem with shaft play and worn out parts. so if you go looking at them, make sure to see if the turbo has much shaft play, and that the supercharger rolls over nicely. to be honest with ya, if its an older block, id just go for a slight N/A tune and be done with it, because if your already happy with how quick it is, the addition of a power adder, is just going to make you want more boost,,,more speed...its a drug. besides if your going to add any major power, your going to want to rebuild for the block to handle the added boost, and your going to want to invest in a good system. all this will definitely go over your price range, but that’s all your decision.
EERNGER98 is offline   Reply With Quote
Old November 9th, 2007, 12:56 PM   #9
EERNGER98
EERNGER98's Avatar
at the same time tho, if you got to be good friends with your local salvage yard, you could score a s-charger off of a totaled mustang or something and probibly be at or under your price range. its a thought...for everything else theres ebay!
Old November 10th, 2007, 12:05 PM   #10
Blackbeast2
Hardcore since 84
im still in the debate mode, as I might just redo ever thing with parts from the murarder. I have been some reaserch on the mustang forums and came across allen supercharges i can score one for 3k. O I have all ready been bitten by the speed bug but untill latley its just been on my bike..
Old November 12th, 2007, 08:55 AM   #11
jackedup88
cushman
jackedup88's Avatar
you can find a good super charger for 3k. but for that much you could also make a good turbo setup. is the engine your boosting built lower end? and like others said up top, you should get some good head gaskets. the supercharger would be easier to controol boost with ( keep you in the safe boost area) with the turbo set up you could have boost spikes- and boost creep which could be the end of a stock engine.- dont forget you might have to do some ecm work, and ( depending on boost) you might have to get more fuel to engine/ bigger injecters.
jackedup88 is offline   Reply With Quote
Old November 15th, 2007, 11:28 AM   #12
ScOoTeR
hoo dat. wat.
ScOoTeR's Avatar
I believe he's talking about boosting a stock 4.6 2V
@clarkstoncracker
Old November 15th, 2007, 11:43 AM   #13
mezzfit
NWOC
mezzfit's Avatar
Check out www.turbomustangs.com I have a friend that went from knowing nothing about turbos to building a twin-turbo Malibu station wagon.
mezzfit is offline   Reply With Quote
Old November 15th, 2007, 11:44 AM   #14
scramblerman72
Moonlight stomper
scramblerman72's Avatar
Send a message via AIM to scramblerman72 Send a message via MSN to scramblerman72 Send a message via Yahoo to scramblerman72
NOS is onlybad for engine when ran wrong or to much for the build you have done done right it wont hurt your motor but requires timing and fuel mixture to be changed to run on motor or nos so you allways have to mess with it
That said
SC work constantly and allso can abuse the motor so if your worried about the motor allready better not use much boost. plus drags down the motor as its belt driven in your aplication, if the belt breaks the car is dead as no air/fuel can get by the impeller .. but easier to install and requires no exaust mods
Turbo's and the best all around power adder IMO as they come on only wheen needed, use the exaust to turn and frees up the pullies IF they fail the car can still limp home or on the trailer its just a choked out motor
but requirs exaust mods.... that all i have as I have never played with Ford SC or Turbos so I can tell you what to use just pointing out some pros and cons between the 2 incase you missed some thing!
scramblerman72 is offline   Reply With Quote
Old November 15th, 2007, 11:57 AM   #15
dragginwagon406
Adrenaline Junkie
dragginwagon406's Avatar
EFI or Blow-through?
Check out TM.com and the blow through database - many examples to copy.
dragginwagon406 is offline   Reply With Quote
Page generated in 0.46877 seconds with 69 queries
