Go Back   Great Lakes 4x4. The largest offroad forum in the Midwest > 4x4 Talk > Jeep Tech > Jeep tech FAQ
GL4x4 Live! GL4x4 Casino GL4x4 Arcade
Jeep tech FAQ Look here first!
Thread Tools Display Modes
Old November 10th, 2005, 08:33 PM   #1
Motor Slut
I put the Ick in Dick.
Motor Slut's Avatar
Everything 4.0L, casting#, parts, differences
Courtesy of Dino at http://jeep4.0performance.4mg.com/tech_specs.html
The following is a list of the injectors used on the 4.0L since 1987 along with their rated static flow:
Model Year, ...Part #, ......Colour, .....Fuel Pressure, ...Static Flow,
'87-'90, ........53003956, ...Black, ........39psi, .................18.6lb/hr
'91-'93, ........33007127, ...Brown, .......39psi, .................21.0lb/hr
'94-'95, ........53030343, ...Tan, ...........39psi, .................21.0lb/hr
'96-'99, ........53030778, ...Grey, .........49psi, .................23.2lb/hr
'99-'01, ........04854181, ...Blue tip, .....49psi, .................22.5lb/hr
The injector flow rate varies as the square root of the pressure drop across the injector. The stock '91-'95 4.0 injectors are rated at 22lb/hr @ 43psi fuel pressure, so at 39psi they flow ( sq. rt.(39/43) x 22.0 = 21.0 ).
For stock/modified 4.0 engines or stroker build-ups the following injectors can be installed. The flow rates are:
Ford Motorsport 19.0lb/hr @ 39psi (Part no. FMS-M9593-C302)
Ford Motorsport 24.0lb/hr @ 39psi (Part no. FMS-M9593-A302)
Ford Motorsport 30.0lb/hr @ 39psi (Part no. FMS-M9593-B302)
Chevy LT1 24.0lb/hr @ 43.5psi (Part no. 17124248)
Chevy LT4 28.0lb/hr @ 43.5psi (Part no. 17124251)
Accel 19.2lb/hr @ 44.1psi (ACC-150119)
Accel 21.1lb/hr @ 44.1psi (ACC-150121)
Accel 24.4lb/hr @ 44.1psi (ACC-150124)
Accel 25.6lb/hr @ 44.1psi (ACC-150126)
Accel 29.4lb/hr @ 44.1psi (ACC-150130)
The '95 Jeep 5.2 ZJ/Dodge 5.9 injectors (Part no. 53030262) are rated to flow 24.6lb/hr at 39psi.
The selection of injector size will depend on the estimated horsepower output, brake specific fuel consumption BSFC (assume 0.5), no. of cylinders, and the injector duty cycle (assume 80% or 0.8). The formula is:
Injector size (lb/hr) = (horsepower x 0.5)/(no.of cylinders x 0.8)
Cylinder head
The stock cylinder head is cast iron and weighs 60lb. The valve head diameter is 1.91" intake/1.50" exhaust. Casting numbers are as follows:
Year............Casting No
1987-90......2686
1991-95......7120
1996-98......0630
1999-04......0331
Cylinder head flow figures (cfm) at 25inH2O pressure drop are:
Non-HO head #2686
Valve lift (in)..... 0.2 ... 0.3 ... 0.4 ... 0.5 ... 0.6
Intake flow.... 122.0 168.0 186.0 189.0 192.0
Exhaust flow....88.0 114.0 130.0 134.0 138.0
Ported non-HO head #2686
Intake flow.... 124.0 183.0 197.0 207.0 216.0
Exhaust flow....87.0 113.0 138.0 153.0 159.0
HO head #7120 & #0630
Valve lift (in)... 0.1 ... 0.2 ... 0.3 ... 0.4 ... 0.5 ... 0.6
Intake flow.... 66.0 128.0 179.0 206.0 209.0 209.0
Exhaust flow. 55.0 100.0 120.0 136.0 141.0 141.2
HO head #0331
Intake flow.... 114.0 165.0 194.0 199.0 205.0
Exhaust flow....94.0 117.0 126.0 130.0 133.0
Ported big valve 2.02/1.60 HO head
Intake flow.... 73.9 142.4 197.8 229.8 247.0
Exhaust flow. 65.3 114.0 135.9 146.3 157.1
The early '87-'90 non-HO heads have low intake ports that flow rather poorly. The later HO heads have higher intake ports that flow more air by allowing a straighter shot into the cylinders. The '91-'95 HO heads with casting no.7120 have the highest intake and exhaust port airflows, especially at lower valve lifts where it is most important, and are the best for performance. The '96-'98 0630 heads are almost identical except that they don't have a port for the coolant temp. gauge sending unit. The '99 and later HO heads with casting no.0331 have smaller exhaust ports to produce a faster warm-up of the catalytic converter and improve emissions, but performance also suffers because the ports don't flow as well as those of the 7120 and 0630 castings.
The exhaust ports flow relatively poorly compared to the intake ports on all the 4.0 heads so this engine would perform better with a dual pattern cam that has more exhaust valve opening duration and lift than the intake. Jeep recognised this and increased the exhaust valve opening duration on the '99 and later cam to compensate for the poorer exhaust port flow of the 0331 head.
The intake ports of the HO head are rectangular and measure 1.625" x 1.375", while the exhaust ports are elliptical and measure only 1.375" x 1.250". The port cross-sectional areas are 2.234 and 1.350 sq. inches respectively. For good street performance, it is recommended that the port c/s area should be about 85% of the valve head area. Therefore it should be 2.435 sq. in. for the intake ports and 1.502 sq. in. for the exhaust ports. The stock port c/s areas therefore need to be enlarged by 9.0% for the intake and 11.3% for the exhaust. The ports should be matched to the intake and exhaust manifold runners to smoothen airflow and prevent power-robbing turbulence.
For those who would like to undertake a DIY head porting job, the Standard Abrasives DIY Head Porting Guide is a must read.
Head gaskets
The compressed thicknesses of the following gaskets for the 4.0 engine are:
Stock 4.0 (all years) #53020754AB----0.051"
Mopar Performance #P4529242/Victor Reinz Dana #5713----0.043"
Corteco #20667CS '87-'95, #20871 '96-'05 ----0.051"
Fel-Pro #9076PT1----0.051"
Pistons
The pin heights and dish volumes of pistons available for the 4.0 engine are:
Stock 4.0 cast aluminium '87-'93 #83500251, '94-'95 #4773157, '96-'04 #4798329----1.601" 13.1cc
Keith-Black Silvolite hypereutectic 2229----1.581" 11.5cc
Speed Pro hypereutectic H825CP----1.592" 15.8cc
Speed Pro cast aluminium 677P/677CP----1.585" 17.5cc
Intake manifold
The '91-'95 intake manifold is aluminium and has equal length 24cm (9.5") long runners. The runners are rectangular with internal dimensions of 1.625" x 1.375", with a cross sectional area of 2.234 sq. in. The distance from the intake valve to the port opening is 9cm (3.5"), making the total distance 33cm (13") from the manifold plenum wall to the intake valve.
For a given intake manifold design, the cross-sectional area of the runner affects the location of an engine's torque peak in the RPM band. The runner length also has an effect, but not as much. According to this formula:
Peak Torque RPM = [Intake Runner Area (sq. in) X 88200] / Cylinder Volume (cu. in.)
Substituting 40.25 for the cylinder volume and 2.234 for the intake runner area, the result is that the runner area is tuned for a peak torque at 4900rpm. That's close to peak HP rpm on the 4.0 engine.
According to the Helmholtz tuning model and the formula shown here, the intake runner area and length are tuned to resonate and produce an inertial supercharging effect at 5000rpm. That's also close to peak horsepower rpm.
Exhaust manifold
The same design principles for the intake manifold also apply to the exhaust manifold. The cross-sectional area of the primary header pipe affects the location of an engine's torque peak in the RPM band. The pipe length generally will not change the peak torque or the RPM at which it occurs. A length change has the effect of improving the torque on only one side of the peak by "borrowing" it from the other side. A shorter pipe improves torque after the peak (reduces it at lower RPM), preventing the torque curve from falling off so quickly as speed increases. A longer pipe extends the torque curve backwards to improve the engine's flexibility, at the expense of after-peak torque.
The stock exhaust manifold and the Borla header have a primary pipe internal diameter of 1.375" and a cross sectional area of 1.49 sq. in. Using this formula:
Peak Torque RPM = [Primary Pipe Area (sq. in) X 88200] / Cylinder Volume (cu. in.)
the stock exhaust manifold and the Borla header are tuned to a peak torque of 3265rpm. That's right at the peak torque rpm of the 4.0 engine.
Old November 10th, 2005, 08:34 PM   #2
Motor Slut
Motor Slut's Avatar
Block Casting Numbers
1987-90......53005535 (8933002665)
1991-95......53008405
1996-98......53020569
1999-04......53010449
Crankshaft Casting Numbers
The stock Jeep 4.0 crankshaft is nodular iron, has 8 counterweights, and weighs 55lb.
Year............Casting No.........Part No.
1987-90......3003453..........83503409
1991............3003453..........83507107
1992............3003453...........4638952
1993-95......3003453...........4728882
1996............53020767.........4728882
1997-98......53020767.........4864726
1999-04......53010411
Connecting Rod Casting Numbers
Stock Jeep 4.0 rods are cast iron, 6.125" long from center to center, and weigh 660g. The casting no. is 53020126 for all years.
Pushrods
Stock pushrods are oil-through type with pressed-in balls at each end. They are 5/16" in diameter and 9.625" long
Pilot Bearings
The 5-speed manual transmission is the light-duty Peugeot BA10/5 in the '87-'89.5 4.0 XJ, the medium duty Aisin-Warner AX15 in the '89.5-'99 4.0 XJ, and the medium-duty New Venture Gear NVG3550 in the '00-'01 4.0 XJ. When carrying out engine swaps (either another 4.0 or a stroker), selection of the correct pilot bearing can be a headache. The details below will make choosing a pilot bearing simple:
'87-'89.5 BA10/5:
OEM pilot bearing 33004041 for '87-'91 4.0 engine
Advance Adapters pilot bushing 716120 for '92-'04 4.0 engine
*Upgrade transmission to AX15 or NVG3550 for stroker engine swap*
'89.5-'91 AX15:
OEM pilot bearing 33004041 for '87-'91 4.0 engine or stroker
'92-'99 AX15 and NVG3550:
OEM pilot bearing 53009180AB for '87-'91 engine or stroker
OEM pilot bearing 53009180AB or 53009181 for '92-'04 4.0 engine.
Stock Cam Specs
The stock '87-'95 Jeep 4.0 camshaft is a single pattern cam with the following specs:
Advertised duration int./exh.: 270.0/270.0 deg
Duration @ 0.050" lift int./exh.: 197.0/197.0 deg
Valve lift int./exh.: 0.424"/0.424"
Lobe separation angle: 112 deg
Intake centerline angle: 110.5 deg
Valve overlap: 46 deg
IVO: 12 deg ATDC (0.050" lift)
IVC: 29 deg ABDC
EVO: 32 deg BBDC
EVC: 15 deg BTDC
The stock '96 and later Jeep 4.0 camshaft is a dual pattern cam with the following specs:
Advertised duration int./exh.: 256.0/260.0 deg
Duration @ 0.050" lift int./exh.: 188.0/192.0 deg
Valve lift int./exh.: 0.408"/0.414"
Lobe separation angle: 107.5 deg
Intake centerline angle: 100 deg
Valve overlap: 43 deg
IVO: 6 deg ATDC (0.050" lift)
IVC: 14 deg ABDC
EVO: 30 deg BBDC
EVC: 18 deg BTDC
Old November 16th, 2006, 04:33 PM   #3
Captain Ledd
Ranger Addiction?
Captain Ledd's Avatar
forget it.
Old November 16th, 2006, 04:36 PM   #4
EL BURRO
33's is how I roll
EL BURRO's Avatar
boy, do you have alot of free-time.!
EL BURRO is offline   Reply With Quote
Old May 4th, 2007, 02:06 PM   #5
nick_n_ii
nick_n_ii's Avatar
Send a message via Yahoo to nick_n_ii
Good info there
nick_n_ii is offline   Reply With Quote
Old January 12th, 2008, 11:55 AM   #6
Enginecraft
Engine Machining & Parts
Enginecraft's Avatar
Exclamation
Well I can tell you that a 99 1/2 and up XJ 4.0 block is all on it's own. The Wrangler and Grand Cherokee use a different block with differing mount bosses/oil filter setup.
Enginecraft is offline   Reply With Quote
Thread Tools
Display Modes
Powered by: vBulletin Version 3.7.0ß
Copyright ©2000 - 2009, Jelsoft Enterprises Ltd.
Copyright ©2005 - 2009 Cracker Enterprises - Powered by Linux
Forums Directory
Page generated in 0.26479 seconds with 24 queries
