WTF...Dana 61? - Great Lakes 4x4. The largest offroad forum in the Midwest
Old November 4th, 2007, 04:21 PM   #1
Boomie69
It's an addiction
Boomie69's Avatar
Default WTF...Dana 61?
I found a really good deal yesterday on what was advertised as a Dana 60 rear axle out of a 79 F250 for $25. My first thought was that there must be something wrong with it. ie broken shaft, cracked tube. etc. But for $25 I decided that I would go take a look at it. It appeared to be in excellent shape so I paid for my future CJ7 rear axle and went home. Today, after doing a lot of research, I find that I no longer own a Dana 60, I have a Dana61. WTF is a D61 and where do I find information on it? The only information I can find says that parts are not interchangeable with a 60 and good luck finding parts (Gears, carriers, Lockers etc.) for the 61. Has anyone had any experience with D61's?
Boomie69 is offline   Reply With Quote
Old November 4th, 2007, 04:54 PM   #2
PavementPounder
PavementPounder's Avatar
You find information on it via Google, like any other axle: http://www.google.com/search?hl=en&q...=Google+Search
They are not compatible with Dana 60 differential parts, but can be worked with. With gas mileage becoming an issue in the 70's, the Dana 61 was created to support gear ratios taller than what the Dana 60 was initially designed to handle. Read through both pages here. Most of the pertinent information is at the top of the second page.
Old November 4th, 2007, 06:47 PM   #3
mean_greenEXJAY
YJ now
mean_greenEXJAY's Avatar
It was for gear ratios taller 3.54, I had one in the front of a dodge cummins. I belive that every thing is the same just the pinion center line was moved over to support the higher gears, so you can run a ring gear spacer to run lower gears, I am not entirerly sure on that or what spacer you need.
Old November 4th, 2007, 07:24 PM   #4
PavementPounder
This is what is covered at the top of the second page of the POR link I posted.
Old November 5th, 2007, 06:38 AM   #5
Boomie69
It's an addiction
Boomie69's Avatar
Thanks for the info guys. Maybe I'll investigate the spacer idea before I scrap it. If I do proceed I'll let you know how it goes. Thanks
Old November 5th, 2007, 07:28 AM   #6
PavementPounder
It would be worth looking into considering the price you got it for. What you should research first is shaft compatibility, etc in case of breakage. Considering most people don't want to mess with them, you'll probably find that entire axles are cheaper than specific parts if you bust something.
Old November 5th, 2007, 10:20 AM   #7
JohnnyJ
Low Range Drifter
JohnnyJ's Avatar
More info on pirate4x4:
http://www.pirate4x4.com/forum/showthread.php?t=245900
Or call Sean (Gearman on pirate4x4) at River City Diff
916-852-7109, he knows the skinny on the D61 stuff.
Old November 5th, 2007, 11:35 AM   #8
BIGBEN
All out Idiot
BIGBEN's Avatar
agree with PP. the 61 is an oddball axle and parts to repair my make it not such a great deal.
Originally Posted by Stan View Post
My hope is that one day all women will realize just how well they could have it if they just shut their big fucking whining mouths.
BIGBEN is offline   Reply With Quote
Page generated in 0.37836 seconds with 47 queries
