D44 Hub question - Great Lakes 4x4. The largest offroad forum in the Midwest
Old November 4th, 2007, 12:53 PM   #1
Fraser
Fraser's Avatar
Default D44 Hub question
I have just aquired a 77 D44 HD front, it is a eight lug axle, and i was wondering if i could use a regular D44 five lug hub. because im lookin at running a 9" rear b/c i have no real need for a ff one ton rear end
Old November 4th, 2007, 01:19 PM   #2
Renegade II
Coil springs are for pens
Renegade II's Avatar
What was the 44 in? Is it a Ford with the big dual piston caliper? If so I believe you have to change the caliper mounting bracket and spindle, as well as the hub and caliper.
Old November 4th, 2007, 03:22 PM   #3
Fraser
Fraser's Avatar
yes, it has the dual piston caliper on it. it was in a 77 3/4 ton f-250, leaf sprung
Old November 4th, 2007, 05:58 PM   #4
PavementPounder
PavementPounder's Avatar
Renegade is correct. You can change it all over, but you may very well spend less money on the matching D60 rear than you would buying all the 5x5.5" parts (if you don't already have them.) PM me if you don't have them yet.
Old November 4th, 2007, 08:33 PM   #5
Fraser
Fraser's Avatar
hmm, looks like im gonna run the 60 rear, just for the ease of doing things. but i do have lots of time to think this one over...
Old November 4th, 2007, 08:38 PM   #6
frdtrckmnrich
FORD The Best Never Rest
frdtrckmnrich's Avatar
knuckles out from a 70's ford would be a direct swap and they also use the same axle shafts.
Old November 4th, 2007, 08:42 PM   #7
Fraser
Fraser's Avatar
ok, cool i totally forgot to ask about the shafts, b/c i need one:tonka: so, i can use regular d44 shafts in this HD axle
Old November 4th, 2007, 11:06 PM   #8
frdtrckmnrich
As long as they are from a ford dana 44
Old November 4th, 2007, 11:09 PM   #9
Fraser
Fraser's Avatar
well, ya my bad:tonka:
Old November 4th, 2007, 11:36 PM   #10
Toivo
Feel lucky?
Toivo's Avatar
I just built this exact axle.
Superwinch lockouts are $170 at my cost, which isn't normal price.
Regular D44 shafts did not fit in mine, only D44 HD ones. I tried to use a chevy short side inner and it didn't fit the splines.
I would avoid this axle, or go back to what spro said and convert.
Doing the brakes is a real fucking gem, too.
Old November 4th, 2007, 11:47 PM   #11
Fraser
Fraser's Avatar
ya, i think i saw that its a certian year range that the regular shafts didnt work, im gonna have to go back and look at that. how is it such a 'gem', theyre disc
Old November 4th, 2007, 11:53 PM   #12
Toivo
Feel lucky?
Toivo's Avatar
To put the pads in, you have to remove the rotor. Teh gayness design.
it takes far less time to change the caliper than the pads.
Old November 5th, 2007, 12:01 AM   #13
Fraser
Fraser's Avatar
that dont make too much sense, so im gonna check that out tomarrow haha
Old November 5th, 2007, 12:02 AM   #14
Toivo
Feel lucky?
Toivo's Avatar
Also, lockouts are FAWKING EXPENSIVE!!!!!
Old November 5th, 2007, 07:37 AM   #15
frdtrckmnrich
I have two of those axles and not one do you have to remove the rotors to do pad changes. If you use the hd outers you have to use the expensive lockouts. If you change the outers to 1/2 ton stuff you can use regular lockouts. It has been my experiance that the only differences between the hd's and regular are: The hd's have thicker tubes and everything from the knuckles out is bigger.
Old November 5th, 2007, 02:03 PM   #16
Toivo
Feel lucky?
Toivo's Avatar
Whelp, seeing as how I couldn't manage to have the rotors bolted on and tightened down, and then try to assemble the pads in the pad slides without the caliper bolted down, it was easier for me to pop the rotor off and put the slide over the rotor, and then push it all into place and retighten the rotor down.
My $0.02. Didnt say it was the proper way, just the way I found easiest.
Old November 5th, 2007, 05:04 PM   #17
Fraser
Fraser's Avatar
yes, thats what im lookin for info wise, thanks. i think my buddy said it was more like a 60-ish housing
Old November 5th, 2007, 05:10 PM   #18
Fraser
Fraser's Avatar
interesting...it looks like to me, that two big bolts, and a little bolt and plate on the btm of the caliper hold it down
Old November 5th, 2007, 05:56 PM   #19
PavementPounder
If you look on Mr. N's site, you'll see pictures of what the actual differences are.
:tonka:
Old November 5th, 2007, 06:01 PM   #20
Toivo
Feel lucky?
Toivo's Avatar
Originally Posted by PavementPounder View Post
:tonka:
:tonka:
Page generated in 0.34033 seconds with 83 queries
