4.0 and 2.3 manual trans - Great Lakes 4x4. The largest offroad forum in the Midwest
Old November 3rd, 2007, 02:10 PM   #1
caveman
GeoDude
caveman's Avatar
Default 4.0 and 2.3 manual trans
just picked up a 92 xploder with a 4.0 and a 5 speed (M5OD-r1) the 5 speed is junk.
in my garage for no reason there is a 96, 2.3(that's blown) with a good 5 speed M5OD-r1. anyone see where i'm trying to go with this? could i be lucky enought that it would bolt up?
Old November 3rd, 2007, 02:27 PM   #2
caveman
GeoDude
caveman's Avatar
scratch that idea. the starters are on different sides, now i'm gonna see if i can transfer the guts...
Old November 3rd, 2007, 05:14 PM   #3
chris1044
chris1044's Avatar
Whats wrong with the trans?? just curious
Old November 3rd, 2007, 05:37 PM   #4
caveman
GeoDude
caveman's Avatar
on the input shaft in the very front where is meets the first bearing, the bearing ran dry and welded itself to the shaft and broke it.
Old November 6th, 2007, 10:19 AM   #5
fsumotorhead
N8KVB
fsumotorhead's Avatar
Make sure when you get a new one, replace the plugs on top with metal ones. Thats probably where the fluid went.
Old November 7th, 2007, 07:28 AM   #6
Tom
Because racecar
Tom's Avatar
the guts are interchangeable... 99% sure
Old November 14th, 2007, 01:06 PM   #7
Jrod-13
poser wheeler
the gear ratios are different between the two... but they should still swap.
Jrod-13 is offline   Reply With Quote
Page generated in 0.22100 seconds with 44 queries
