Diff Fluid - Great Lakes 4x4. The largest offroad forum in the Midwest
Old November 2nd, 2007, 02:22 PM   #1
shawn
Resident HVAC/R Jambi
shawn's Avatar
Default Diff Fluid
What viscosity should be used in the diffs? I got 44's, with Detroits, and I have normally run 80/90W, but recently I've seen many things using the 140W stuff. What do you use?
Old November 2nd, 2007, 02:25 PM   #2
Bishop
Bishop's Avatar
Old November 2nd, 2007, 02:28 PM   #3
luvitmyjeep
broken
luvitmyjeep's Avatar
i use royal purple 85/140 for l/s and traction devices
luvitmyjeep is offline   Reply With Quote
Old November 3rd, 2007, 06:12 AM   #4
Yetti
Buy a Fiat! Save the UAW!
Yetti's Avatar
when I was doing Gm stuff at the dealer I used 80/120w in the big diffs with no posi. everything else got the premium Gm Posi oil with friction modifier
Yetti
Old November 3rd, 2007, 07:16 AM   #5
zjkid
zjkid's Avatar
zjkid is offline   Reply With Quote
Old November 3rd, 2007, 09:53 AM   #6
sodapop
Support the Sport!
sodapop's Avatar
I use cheap 80/90 because I like to change it every couple trips or so.
Old November 3rd, 2007, 06:05 PM   #7
OnlyInMyXJ22
No Money = No Fun
OnlyInMyXJ22's Avatar
*2007 Rubicon
*2006 Duramax
Old November 3rd, 2007, 06:26 PM   #8
xjmichigan
xjmichigan's Avatar
140w for the rear
80/90 front
Old November 3rd, 2007, 07:16 PM   #9
GNJEEPN
Grumpy Grampa
GNJEEPN's Avatar
Generally for off road use you only need 80/90 unless you are running a limited slip. Limited slips usually require 75/140 synthetic. The only reason for running a heavier wt gear lube is if you have a heat problem in the diff. This is usually caused by higher speeds. In cooler weather heavier gear lube will not lubricate as well since it has a harder time getting to the bearings where it is needed most.
GNJEEPN is offline   Reply With Quote
Old November 3rd, 2007, 07:20 PM   #10
jmdzuk
jmdzuk's Avatar
yup x2
and if I have one thats a little sketchy I use Lucas(SP)
jmdzuk is offline   Reply With Quote
Old November 3rd, 2007, 08:26 PM   #11
Jeeperz Creeperz
GL 4x4 Vendors
Jeeperz Creeperz's Avatar
X3
The synthetic stuff is too pricey to put in a trail rig.
If it's your DD, you could run the synth stuff.
Old November 3rd, 2007, 08:27 PM   #12
Jeeperz Creeperz
GL 4x4 Vendors
No, limited slips require an additive.
The newer vehicles run the synthetic and an additive, but you can still run 80/90 with the additive.
Old November 3rd, 2007, 09:47 PM   #13
DuffMan
Your Message Here
DuffMan's Avatar
Gear-driven Detroit TruTrac LSD doesn't require a friction modifier because it doesn't have clutch packs.
Page generated in 0.30142 seconds with 62 queries
