Welding on the Center chunk ? - Great Lakes 4x4. The largest offroad forum in the Midwest
Old November 1st, 2007, 06:48 PM   #1
Mclovin
"The Situation"
Mclovin's Avatar
Default Welding on the Center chunk ?
I got a waggy Dana 44 and i need to weld my spring perch on the pass side on that part that's one with the center chunk ? How do i do this ?? Ive heard it needs a lot of heat ? meaning.... Heat the center chunk up with a torch ? use a big bad ass 210 mig welder on the highest setting ?? ( i only have a 110 Mig and a old 210 buzz box lincoln arc welder)
Old November 1st, 2007, 06:52 PM   #2
BMFmike
meh.
BMFmike's Avatar
What the hell is the center chunk? The pumpin?
Old November 1st, 2007, 07:16 PM   #3
Jeepaholic
Axle Guru Extraordinaire
Jeepaholic's Avatar
couple ways to do it but usually lots of heat and high nickle rod with the arc welder, make sure it cools slowly. Although I don't think it is a big deal with a spring perch
Old November 1st, 2007, 07:19 PM   #4
pyrowaves
The Boss
pyrowaves's Avatar
Send a message via AIM to pyrowaves
He wont call it anything but that... I've tried.. its useless.. haha :miff:
pyrowaves is offline   Reply With Quote
Old November 1st, 2007, 07:21 PM   #5
Mclovin
"The Situation"
Mclovin's Avatar
YES I AM SPEAKING OF THE LARGE PART OFFSET TO ONE SIDE IN THE FRONT TECHNICALLY CALLED THE DIFFERENTIAL HOUSING
Old November 1st, 2007, 07:25 PM   #6
Mclovin
"The Situation"
Mclovin's Avatar
ic... so get it cherry red or just heat it up ?
Old November 1st, 2007, 07:35 PM   #7
pyrowaves
The Boss
pyrowaves's Avatar
so no being a dick and squirting water on it while i have the torch on it.... oh wait.. that was ME you got with the water!!
Old November 1st, 2007, 07:36 PM   #8
Jeepaholic
Jeepaholic's Avatar
heard some people cover it in a sand pile or wrap it in insulation (r13 )
should still be warm hours later, next morning is better
Old November 1st, 2007, 07:57 PM   #9
hosejockey4506
Visiting Admin
hosejockey4506's Avatar
i think its only 350 degrees you would heat it to, goto a welding shop[ and buy a heat stick if your that concerned, if not goto tsc buy some nickel rod and just weld it. if it was mine i would just mig weld, its not gonna break its a leaf spring perch
Old November 1st, 2007, 08:33 PM   #10
jmdzuk
jmdzuk's Avatar
x2
jmdzuk is offline   Reply With Quote
Old November 1st, 2007, 08:58 PM   #11
Mclovin
"The Situation"
Mclovin's Avatar
thats kinda what im thinking just hit it with the little mig.. Theyre just perches.. but i will heat it a bit 1st
Maybe ill bring my infa red thermometer home and do it all fancy
Old November 1st, 2007, 08:59 PM   #12
Mclovin
"The Situation"
Mclovin's Avatar
There's was FIRE !!! Sorry i got you a little too :tonka:
Old November 1st, 2007, 09:20 PM   #13
sglide
co captain of cubes pants
sglide's Avatar
yes to the mig.
no need for nickle rod or pre-heat or slow cool.
its cast steel, not cast iron, nickle rod is a waste in this case and wont be as strong as mig.
also no need to turn a mig welder all the way up.
cast steel welds very easily with all steel welding processes.
sglide is offline   Reply With Quote
Old November 1st, 2007, 09:32 PM   #14
Jeepaholic
Jeepaholic's Avatar
The housing is iron, the inner c is steel
Old November 1st, 2007, 09:38 PM   #15
hosejockey4506
Visiting Admin
Originally Posted by sglide View Post
yes to the mig.
center is cast iron not, knuckles and c's are cast steel
Old November 1st, 2007, 09:46 PM   #16
Mclovin
"The Situation"
Mclovin's Avatar
Originally Posted by One Arm Steve View Post
He only has a 110 mig???? 100 amp???
i beleive the max amp on it is 68 but im not 100% sure..
Here's a pic of it
Old November 1st, 2007, 09:46 PM   #17
sglide
sglide's Avatar
must be very low corbon iron. dosnt cut or weld or grind like cast iron.
and didnt come up red on acid test befor i did nate4d's???????
Old November 1st, 2007, 10:26 PM   #18
sodapop
Support the Sport!
sodapop's Avatar
we just welded mine slowly with a MIG. ie welded part of one side then waited, then welded more then waited then welded then waited. I haven't had any problems at all.
Old November 2nd, 2007, 12:05 AM   #19
PavementPounder
PavementPounder's Avatar
How do i do this ??
Outboard your spring and don't. :tonka:
Old November 2nd, 2007, 05:51 AM   #20
jmdzuk
jmdzuk's Avatar
Flux Core
Page generated in 0.39113 seconds with 83 queries
