3.0l V6 - Great Lakes 4x4. The largest offroad forum in the Midwest
Old October 31st, 2007, 09:03 PM   #1
Ebs
Default 3.0l V6
Are these known for being 'noisy' engines? I checked out one today and it sounded almost like a diesel, a noticeable 'clacking' from the top end. I've read these are know for toasting rod bearings once the head gaskets go...which the gaskets have recently been done.
What will a bad rod bearing sound like?
I don't know if this is just some valvetrain/timing clatter or a noisy fuel injector or what. Do these engines up a timing chain or belt? (could be chain slap)
Old October 31st, 2007, 09:19 PM   #2
bajatoy53
Raisin
bajatoy53's Avatar
Timing belt
bajatoy53 is offline   Reply With Quote
Old November 1st, 2007, 01:14 AM   #3
Milwaukee
Send a message via AIM to Milwaukee Send a message via Yahoo to Milwaukee
3.0 uses a belt....and yes they are noisy....mine has been clattering for two years now....never gives an inch on power tho...over 200,000. on the engine and been rolled twice
Milwaukee is offline   Reply With Quote
Old November 1st, 2007, 04:55 PM   #4
Ebs
If it does have a rod knock shouldn't it quiet down if I pull the plug wire to that particular cylinder?
Old November 1st, 2007, 07:39 PM   #5
skife
skife's Avatar
that would be a spark knock.
rod knock is in the bottom end.
Old November 1st, 2007, 08:41 PM   #6
landrollover
landrollover's Avatar
Send a message via AIM to landrollover
Yup, if theres a lower end noise pulling the plug will help dtermine which cylinder it is.
landrollover is offline   Reply With Quote
Old November 3rd, 2007, 08:12 PM   #7
scubarunner
UPPER('4x4') = '$X$'
scubarunner's Avatar
I have noticed on mine that the fuel injectors make a ton of noise. Sounds like valve clatter in the top end.
scubarunner is offline   Reply With Quote
Page generated in 0.19950 seconds with 44 queries
