dual tank problem, 95 f-350 - Great Lakes 4x4. The largest offroad forum in the Midwest
Old October 30th, 2007, 10:58 PM   #1
jeeperbrian
GLFWDA member
Default dual tank problem, 95 f-350
got a 95 f-350 with dual tanks, when i try to put gas in the front tank the pump shuts off or it will over flow like its full, except its empty. any tips, is there a screen in there that might be clogged up?
Old October 31st, 2007, 07:07 AM   #2
s_burby
just floor it!
s_burby's Avatar
It is not that hard to look at the front, just check to make sure there is not a kink in the fill hose, you might have to re adjust the hose, as far as a screen there should not be anything in the way just a few bends. Or try not running the pump at full blast, i had one of my tanks on my 96 F-350 that i couldnt use the turbo setting at the pump.
s_burby is offline   Reply With Quote
Old October 31st, 2007, 07:30 AM   #3
Chiefwoohaw
Pokerob is my B*tch!
Chiefwoohaw's Avatar
x2 but in my situation it's my rear tank. Want to switch gear tanks so you have a matching set??
Old October 31st, 2007, 08:21 AM   #4
Lothos
KD8GKB
Lothos's Avatar
sounds like a plugged "burping" line. The pump shuts off because it is sensing back pressure in the fuel fill. I'd take the fill hose off the tank and run a pipe cleaner thru the hose and the tube.
Old October 31st, 2007, 08:25 AM   #5
Bones
Bones's Avatar
yup, air can't leave the tank
Inviscid Motorsports
Motorcity Machines
Branik Motorsports
Maxxis Tires
Raceline Wheels
PAC Racing Springs
Joint Clutch and Gear
Old October 31st, 2007, 08:56 PM   #6
jeeperbrian
GLFWDA member
cool, thanks for the advice. ill try it this weekend
Old November 1st, 2007, 08:06 AM   #7
Chiefwoohaw
as well
Page generated in 0.17159 seconds with 44 queries
