solid axle exo tracker - Great Lakes 4x4. The largest offroad forum in the Midwest
Old October 30th, 2007, 10:17 PM   #1
A4X4SPIT
A4X4SPIT's Avatar
Default solid axle exo tracker
got a new progect going 4dr tracker 1.616v auto trans bought it wrecked put a samurai axle in the ft & put 5.12 gears in axle( spool in rear) exo cage steel bumpers 35 " boggers
ID:	16571   Click image for larger version
ID:	16572   Click image for larger version
A4X4SPIT is offline   Reply With Quote
Old October 30th, 2007, 10:18 PM   #2
stevelknievel
Fuck Cancer
stevelknievel's Avatar
Send a message via AIM to stevelknievel
that is badass!
stevelknievel is offline   Reply With Quote
Old October 30th, 2007, 10:23 PM   #3
aimmotorsports
aimmotorsports's Avatar
nice. im working on a '92 2 door. going with 3/4 ton chevy axles and 37"ssr's for now. will be doing a 4.3 swap in spring hopefully...
aimmotorsports is offline   Reply With Quote
Old November 12th, 2007, 09:16 PM   #4
A4X4SPIT
A4X4SPIT's Avatar
got a little more tim on the tracker did some quick painting & some shake down wheelin had to space the ft tires w/ spacersI I purt the old ft coils in the rear I may have to get some t/c gears or put a samurai t/c behind the tracker case alto its gone where Ive pointed it so far
Old November 12th, 2007, 09:37 PM   #5
scottie
Eye candy
scottie's Avatar
How does your Front axle like the 35's?
Old November 12th, 2007, 10:14 PM   #6
Chop
Mischievous Badger
Chop's Avatar
how did you bend that cage? what did you use
Old November 13th, 2007, 03:57 AM   #7
A4X4SPIT
A4X4SPIT's Avatar
I had those 35s on the samurai (v-6 auto)the axle came out of for more than a year & no issues
I bent the cage w/a home made bender that uses pro tool dies & a 20 ton air operated bottle jack
Old November 13th, 2007, 12:21 PM   #8
Bones
Bones's Avatar
why run the rear boggers in reverse?
Inviscid Motorsports
Motorcity Machines
Branik Motorsports
Maxxis Tires
Raceline Wheels
PAC Racing Springs
Joint Clutch and Gear
Old November 13th, 2007, 04:05 PM   #9
A4X4SPIT
A4X4SPIT's Avatar
why not ..all the cool guys are .. just the way they were stacked when I first put them on to check clearences & I figure Ill have em off sooner than later & Ill swap em around then
Old November 15th, 2007, 10:31 PM   #10
epike7915
Team Kamikaze 4x4
epike7915's Avatar
He has been getting away with using the 35's and tractor bars on the sammy front axle by keeping it OPEN. That really helps on the stress.
epike7915 is offline   Reply With Quote
Old November 15th, 2007, 11:15 PM   #11
scottie
Eye candy
scottie's Avatar
yeah i've seen it done before, but i was just curious if he broke birfields often, etc.
Old November 15th, 2007, 11:32 PM   #12
A4X4SPIT
A4X4SPIT's Avatar
I keep it open because I like to turn
Old November 16th, 2007, 07:38 AM   #13
epike7915
Team Kamikaze 4x4
epike7915's Avatar
Old November 16th, 2007, 08:55 AM   #14
Bronco351
Powered by Ford
Bronco351's Avatar
Send a message via Yahoo to Bronco351
nice, very nice, first time i have ever seen one of these.
Bronco351 is offline   Reply With Quote
Old November 16th, 2007, 09:45 AM   #15
mpsbvp
Hummer recovery team
mpsbvp's Avatar
Send a message via AIM to mpsbvp Send a message via Yahoo to mpsbvp
sweet rig what else u got planed
mpsbvp is offline   Reply With Quote
Old November 16th, 2007, 11:08 AM   #16
nd4spd71
nd4spd71's Avatar
Cool
nd4spd71 is offline   Reply With Quote
Old November 16th, 2007, 03:24 PM   #17
Fraser
Fraser's Avatar
i asked my buddy that, except hes got tractor tires. he said it helps get traction in reverse when you get stuck(he runs a mud truck)
Old November 16th, 2007, 04:43 PM   #18
revho
$9.00 vanilla malt
revho's Avatar
reminds of the video game moon patrol for some reason...
revho is offline   Reply With Quote
Old November 16th, 2007, 05:40 PM   #19
A4X4SPIT
A4X4SPIT's Avatar
I m going to incortorate some roof bars into a rack for the roof probably going to put a samurai t/c behind the tracker t/c Ive done this on another one of my rigs & its still working sweetly even w/ tractor bars or if I find t/c gears cheep enuff Ill go that route this is a budget rig I got under $900. into it & I got it to this point in about 6 weeks heres some build pics it was hit pretty hard in drver ft so I cut off frame & inner fenders and it was RUSTY most of which went w/ the rockers so I could build rock guards exo base
Old January 3rd, 2008, 06:55 PM   #20
A4X4SPIT
A4X4SPIT's Avatar
just got done ading a samurai transfercase behind a modified tracker t/c now it actually rips with the 35s
ID:	18917   Click image for larger version
Page generated in 0.44488 seconds with 84 queries
