XJ Rear Bumber New Finished Pics - Great Lakes 4x4. The largest offroad forum in the Midwest
Old October 30th, 2007, 09:20 PM   #1
badazzamc
Get Some
badazzamc's Avatar
Default XJ Rear Bumber New Finished Pics
Here is what I got so far. It will be a swing out tire carrier. It will also be tied into the hitch. Let me know what you think, good or bad. I will post more pics as the work continues.
Old October 30th, 2007, 09:24 PM   #2
natureboynate47
natureboynate47's Avatar
nice job with theb body lines and the big gap.
natureboynate47 is offline   Reply With Quote
Old October 30th, 2007, 09:26 PM   #3
ddeadserious
ddeadserious's Avatar
Looks nice, will look great once you get a tire carrier on it. One piece of recommendation, you may want to offset the tire to the drivers side, so you can still see out the passenger half of the rear window when changing lanes and stuff. I'm going to rebuild my carrier to be that way, because my rear window is absolutely useless.
Like this:
Nice job following the body lines back though.
ddeadserious is offline   Reply With Quote
Old October 30th, 2007, 09:42 PM   #4
badazzamc
Get Some
badazzamc's Avatar
I like the idea of moving the tire over but how much is it going to sag since all the weight will be way out from the hinge?
Old October 30th, 2007, 09:45 PM   #5
ddeadserious
I was thinking it'd make the most sense to have the hinge be on the driver side by the taillights, apparently Detours USA thought differently, but when I do mine, the hinge will be on the drivers side so there's not too much leverage on it.
What were you planning on using for a hinge?
Old October 30th, 2007, 10:56 PM   #6
Buggy_Tim
(513) 891-8372
Buggy_Tim's Avatar
Looks to me like that tire on that off set one would get hung up on trees and rip the damn thing off.
Old October 31st, 2007, 05:58 AM   #7
badazzamc
Get Some
badazzamc's Avatar
I was thinking a 1" round stock with a something machined to fit over it, with some type of grease fitting in it.
Old October 31st, 2007, 06:32 AM   #8
Chris99XJ
If It Aint ruf It Aint Me
Chris99XJ's Avatar
Nice work
Chris99XJ is offline   Reply With Quote
Old October 31st, 2007, 11:51 AM   #9
ddeadserious
I'd recommend against that; I'd use a trailer hub and spindle; it seems to be the best way to go. It's made to support more than the weight of a tire, is greasable, uses bearings, and will not sag.
read through this guys thread, he's executed it nicely:
http://www.naxja.org/forum/showthrea...=899237&page=5
Many others have used hubs as well. Hopefully someone will chime in with the good latch to use, I just don't remember where to find it.
http://www.greatlakes4x4.com/showthread.php?t=52017
I see you posted there a while back, he has the latch that seems kind of like the universal latch used by many tire carrier makers. I'm not sure I get what he used to the hinge though.
Old November 2nd, 2007, 07:30 AM   #10
comanche38
comanche38's Avatar
Yes, use the trailer spindle and bearings. I use to make them with a pivot point like you described, it worked great for a while and if you removed it often and cleaned and lubed it, it was great, but if not, good luck opening and/or removing the tire carrier. We had to cut the one off of my brothers when we replaced it with a spindle/bearings. I did like that it would stay in any position the way it was, with the bearings it almost opens too easily. You have to watch it. A tire on a swingout can do some damage. haha Nice bumper though.
comanche38 is offline   Reply With Quote
Old November 3rd, 2007, 08:31 PM   #11
badazzamc
Get Some
badazzamc's Avatar
I have a spindle and bearings off an s-10 I belive. I think I am going to try the spindle idea. My only question is what were you putting the races in? Picswould be great. Thank.
Old November 6th, 2007, 08:36 PM   #12
cj7on44's
cj7on44's's Avatar
mr. powel did a good job on that
cj7on44's is offline   Reply With Quote
Old November 6th, 2007, 10:05 PM   #13
Pre4runner
Bike Dude
Pre4runner's Avatar
The pivot is off set so that when you open it and then open the hatch you can clear the tire.
I didn't think of this the first time... and can barely clear a 33" tire plus the somewhat centered problem.
i used a simple pipe set up and pin for a latch but it makes some noise once it runs out of grease, a nice squeak to remind you. I will be making a new one soon with driver side mount for a 36" and full width swing to mount the highlift, jerry can and cb antenna too
http://www.greatlakes4x4.com/showthread.php?t=51673
Old November 11th, 2007, 04:41 PM   #14
badazzamc
Get Some
badazzamc's Avatar
yes he did
Old January 7th, 2008, 10:24 PM   #15
badazzamc
Get Some
badazzamc's Avatar
well i finaly got around to taking some finished pics.
Old January 7th, 2008, 11:28 PM   #16
ddeadserious
Awesome, nice work.
Old January 8th, 2008, 02:41 PM   #17
fsumotorhead
N8KVB
fsumotorhead's Avatar
Nice job Trav
Page generated in 0.29537 seconds with 74 queries
