gearing dana 30 hp - Great Lakes 4x4. The largest offroad forum in the Midwest
Old October 30th, 2007, 02:24 PM   #1
JeepGenocide
JeepGenocide's Avatar
Default gearing dana 30 hp
dana 30 hp 3.55 out of a 95 cherokee woundering, if im re-gearing to 3.73 gears will the stock carrier be ok? do i need anything else besides the R&P for what ever place i get to installe them?
JeepGenocide is offline   Reply With Quote
Old October 30th, 2007, 02:32 PM   #2
Hubbler
Hubbler's Avatar
when i went to 4.11s in my 93 i had to get a new carrirer. But i think the cut off is 4.10s and above. As long as ur bearings are good then u dont need to replace them. U are going to need a new pinion seal. IIRC the install kit was like 50 bucks.
Hubbler is offline   Reply With Quote
Old October 30th, 2007, 02:34 PM   #3
xjmichigan
xjmichigan's Avatar
just curious, why would do all that work to go from 3:55 to 3:73
Old October 30th, 2007, 02:45 PM   #4
tippy
SwampStomper
tippy's Avatar
3:73-5:38
tippy is offline   Reply With Quote
Old October 30th, 2007, 08:07 PM   #5
ajmorell
Originally Posted by tippy View Post
2:72-3:54
3:73-5:38
x2, except I think it's 3:55 down, 3:73 up. According to your post where does 3:55 fall.....I was under the assumption if you had gears lower (higher numerically) than 3:55 you needed the other carrier.
Old October 31st, 2007, 09:15 AM   #6
PavementPounder
PavementPounder's Avatar
3.54 is the actual ratio in Dana axles. 3.55 is what the gears come out to in an 8.25 and some other Chrysler axles. There is no difference and the .01 values are generally understood.
Master install kit.
I also agree that this is a lot of trouble and expense to only bump it up one notch. Are you doing this to match another axle you already have?
Old October 31st, 2007, 09:36 AM   #7
JeepGenocide
yes i pick up an 8.8 with 3.73 gears just going to match that.
Old October 31st, 2007, 10:49 AM   #8
Pre4runner
Bike Dude
Pre4runner's Avatar
Let me know what you end up paying.... i was going to take my axle in but the local place wanted $300... I decided to make a puller instead
Old October 31st, 2007, 11:11 AM   #9
Actually, I believe in that case, its simply how they round it. Its 11 tooth pinion, 39 tooth ring, to give you 3.545. Both the Chrysler and small Dana axles (30, 35, 44) use that 11/39 setup.
Its not the same case as 4.09 (11/45) vs 4.10 (10/41) vs 4.11(9/37), which in fact are three different ratios.
Old October 31st, 2007, 11:16 AM   #10
PavementPounder
Aieeght.
Old October 31st, 2007, 11:25 AM   #11
Aieeght.
You started it
Old October 31st, 2007, 11:30 AM   #12
PavementPounder
No, I'm saying aieeght, as in "okay, I didn't know that ratio difference was a matter of rounding and not a difference in teeth".
Page generated in 0.35229 seconds with 59 queries
