D44 hi steer in XJ no worky - Great Lakes 4x4. The largest offroad forum in the Midwest
Old October 29th, 2007, 08:25 PM   #1
Toivo
Feel lucky?
Toivo's Avatar
Default D44 hi steer in XJ no worky
My hi steer tie rod hits my JKS tracbar, so much that I can't bolt my tie rod in.
Ideas are appreciated. For the record, I am using Extreme Engineering hi steer arms.
Old October 29th, 2007, 08:28 PM   #2
Jeepaholic
Axle Guru Extraordinaire
Jeepaholic's Avatar
Pic would help.
Does the tie rod sit closer to the axle then the drag link?
Old October 29th, 2007, 08:28 PM   #3
Pictures will help.
Old October 29th, 2007, 08:30 PM   #4
Toivo
Feel lucky?
Toivo's Avatar
pics in a few.
Old October 29th, 2007, 08:54 PM   #5
Toivo
Feel lucky?
Toivo's Avatar
It is nite time gimme a break. thats as good as it gets now.
Old October 29th, 2007, 08:57 PM   #6
Jeepaholic
Jeepaholic's Avatar
so are you trying to do high steer or cross over steering?
if high steer are both high steer arms the same length or is the driver side shorter?
Old October 29th, 2007, 08:58 PM   #7
Toivo
Feel lucky?
Toivo's Avatar
cross over + hi steer was my intention.... (does this not work )
the passenger side arm has two holes, one for drag link, one to the tie rod, driver side has just the hole for the tie rod.
Old October 29th, 2007, 09:02 PM   #8
Not really seeing much in the pics.
My guess is its time to refab your track bar mount. You'l got a lot of non-stock parts under there, not easy always to make it fit.
How is your track bar mount compared to the stock dana 30? Can it move rearward at all? Looks like its mounted in front of the axle? Or is it just laying there.
Old October 29th, 2007, 09:05 PM   #9
Toivo
Feel lucky?
Toivo's Avatar
It is the stock D30 mount.
I thought about bending the tracbar out of the way, it bulges forward a good 2 inches currently. Pros, cons to that?
Old October 29th, 2007, 09:06 PM   #10
Jeepaholic
Jeepaholic's Avatar
I haven't seen anyone pull this off without both arms the same length and doing a inverted T set up. That is what I am gonna try on the tj, hopefully it will work.
Maybe a straight track bar you might pull it off but I think your stuck with a crossover set up and flip the tie rod on the knuckles. Unless you get a different driver side arm.
Old October 29th, 2007, 09:10 PM   #11
Toivo
Feel lucky?
Toivo's Avatar
What is an inverted T?
I can't go back to stock steering, I have reamed the pitman arm and bought all the 1 ton steering stuff.
Merh, this be lame.
Old October 29th, 2007, 09:13 PM   #12
Jeepaholic
Jeepaholic's Avatar
Where the drag link hooks to the tie rod by the pass side knuckle.
Run the drag link with the 1 ton stuff to the high steer arm and run the stock tie rod for now.
Edit: stole from jcr but this is a inverted T set up
Old October 29th, 2007, 09:15 PM   #13
Toivo
Feel lucky?
Toivo's Avatar
No have stock tie rod.
No have stock anything.
Pitman arm reamed for 1 ton TRE.
I WILL MAKE THIS WORK!!!
Bending/moving tracbar tomorrow I guess
Old October 29th, 2007, 09:18 PM   #14
Mr. Beefy
BFT!
Mr. Beefy's Avatar
was waiting for that comment
Old October 29th, 2007, 09:20 PM   #15
Jeepaholic
Jeepaholic's Avatar
Pitman arm reamed works for that setup :miff:
Me have a stock tie rod also :tonka:
Good luck,let us know if you get it to work
Old October 29th, 2007, 09:41 PM   #16
Toivo
Feel lucky?
Toivo's Avatar
why wont this work?
Ive seen it done before.
Old October 29th, 2007, 09:45 PM   #17
ddeadserious
ddeadserious's Avatar
That's a really cute diagram.
ddeadserious is offline   Reply With Quote
Old October 29th, 2007, 09:48 PM   #18
Jeepaholic
Jeepaholic's Avatar
tie rod and drag link no likey each other. You have to get the tie rod out away from the axle to clear the track bar.
Old October 29th, 2007, 09:50 PM   #19
Toivo
Feel lucky?
Toivo's Avatar
buuut, can I move the tracbar and then do that steering setup and everything will be wonderful?
Old October 29th, 2007, 09:54 PM   #20
Jeepaholic
Jeepaholic's Avatar
where you moving it to, that is the problem. to many links, springs and mounts in the way.
And on top of all that you will have to severely limit up travel to stop it from hitting the frame.
Page generated in 0.38285 seconds with 83 queries
