2000 explorer 302v8 intermittant stalling - Great Lakes 4x4. The largest offroad forum in the Midwest
Old October 29th, 2007, 04:07 PM   #1
dwkehoss
Angry 2000 explorer 302v8 intermittant stalling
When the truck has been driven and is at operating temp. it periodically starts to run rough and then stalls and then will crank but wont restart. By the time its towed and looked at by mechanics its cooled off , starts and runs fine. Local ford dealer and mechanics are scratching their heads. No codes stored in computer. Has anyone experienced this problem? Havnt tried any road side diagnostics yet so dont know whether fuel or spark problem.
dwkehoss is offline   Reply With Quote
Old October 29th, 2007, 04:28 PM   #2
Hackfabrication
Hack
Hackfabrication's Avatar
Haven't had the problem, and I'm not familiar with the EEC-V. But on the EEC-IV systems there are a number of relays in the wiring that could be malfunctioning. I'd start by looking at the fuel pump relay.
Hackfabrication is offline   Reply With Quote
Old October 29th, 2007, 05:56 PM   #3
Bones
Bones's Avatar
fuel pump is overheating would be my first guess
Inviscid Motorsports
Motorcity Machines
Branik Motorsports
Maxxis Tires
Raceline Wheels
PAC Racing Springs
Joint Clutch and Gear
Old October 29th, 2007, 06:07 PM   #4
chris1044
chris1044's Avatar
x2 - I'd check for fuel press when it dies....if there is none check to make sure the relay is infact working (and not over heating and causing the pump to shut off).
If it's all good I'd check spark.....from there it's the more complex stuff you'd need a scan tool to see (data stream)
If it gets fixed please post back the repair.....I'd be interested to hear what it was
Old November 9th, 2007, 08:27 PM   #5
88fordman
88fordman's Avatar
You could also just have somebody turn the key on after it dies and listen to the fuel tank. If you don't hear the fuel pump then like everybody else said...
88fordman is offline   Reply With Quote
Page generated in 0.26449 seconds with 38 queries
