rubicon axles on 99tj - Great Lakes 4x4. The largest offroad forum in the Midwest
Old October 27th, 2007, 10:08 PM   #1
speedjeep
learn your limits
speedjeep's Avatar
Default rubicon axles on 99tj
was looking at purchasing rubicon axles for my 99 tj and was wondering would be involved in doing the swap or if it would be even worth it.
speedjeep is offline   Reply With Quote
Old October 28th, 2007, 08:19 AM   #2
PavementPounder
PavementPounder's Avatar
You'll need the required hardware to actuate the lockers.
Otherwise, they should bolt in and also give you an instant boost in gearing if you don't already have 4.10's. Your driveshaft lengths will change also.
Old October 28th, 2007, 08:31 AM   #3
Also, just make sure you are getting TJ rubicon axles. JK rubicon axles are now hitting the market, used, and new(for a pretty decent price for brand new axles), which are completely different
Old October 28th, 2007, 02:38 PM   #4
zjkid
zjkid's Avatar
Good call
zjkid is offline   Reply With Quote
Old October 28th, 2007, 07:47 PM   #5
PavementPounder
Good point, but would he care? Would JK axles actually not work under a TJ? Wouldn't he be replacing pretty much everything that would have been incompatible?
Old October 28th, 2007, 08:02 PM   #6
DuffMan
Your Message Here
DuffMan's Avatar
Related question: If I put a Rubicon TJ Rear D44 on my 98 TJ (replacing a D35) would a Rubi driveshaft solve the driveshaft length issue?
Will a Rubi driveshaft attach to my NP231?
Old October 28th, 2007, 08:09 PM   #7
ddeadserious
ddeadserious's Avatar
The Rubi driveshaft is set up for a the 241 Rock-track t-case, and they don't have a slip yoke, so no, the driveshaft isn't really compatible.
ddeadserious is offline   Reply With Quote
Old October 28th, 2007, 08:42 PM   #8
DuffMan
Your Message Here
DuffMan's Avatar
I suspected as much. Thanks.
Old October 28th, 2007, 08:48 PM   #9
I'm going to make a non-educated guess that the suspension mounts would need to be cut off/reworked. The wheels would need to be replaced since the bolt pattern is different. He'd possibly need custom driveshafts since the joints are different, too.
And another non-educated guess that someone spending coin on rubicon axles wants to bolt them in, no fuss, no muss...
Regardless, the rear is discs, right? So the brake system should be given attention at that time, as well.
Old October 28th, 2007, 10:27 PM   #10
PavementPounder
I assumed that he'd have to do something about his driveshafts anyway, but I wasn't thinking that the control arm mounts were going to be vastly different (dimensionally) than a TJ. I agree on the rear disc proportioning, but that might so complicated with the use of a JK prop valve.
And he could always buy Kennedy's wheels/tires if he feels like rolling the dice on getting them. :tonka:
Old October 29th, 2007, 10:11 PM   #11
speedjeep
learn your limits
speedjeep's Avatar
thanks for all the info-once i get around to getting it done ill let you know.
and in regards to it being no fuss-thats the biggest reason and propably less i can screw it up
Old October 29th, 2007, 10:17 PM   #12
Chiefwoohaw
Pokerob is my B*tch!
Chiefwoohaw's Avatar
Come on give yourself a little more credit then that!!
Page generated in 0.24233 seconds with 59 queries
