97 ram 1500 tranny problem - Great Lakes 4x4. The largest offroad forum in the Midwest
Old October 21st, 2007, 09:04 PM   #1
Shotgun
I only wheel with boats.
Shotgun's Avatar
Default 97 ram 1500 tranny problem
My nephew has a 1500, the problem is that if he shifts manually from 1-d it will go fine, if in drive it doesnt want to go at all. any ideas? I was thinking maybe the converter.
He lives in the soo if anyone has any parts that may help.
thanks
Old October 21st, 2007, 10:54 PM   #2
user name
keep your stick onthe ice
user name's Avatar
It wont move at all from a dead stop in drive? In manual 1 it applies the L/R band that wouldn't normally be used in D. There is an overrunning clutch that does the same job in normal D as the band if I'm not mistaken. Thats my guess assuming it wont move at all in D from a stop.
Old October 22nd, 2007, 06:50 AM   #3
KILLER"B"468
Yankabilly
KILLER"B"468's Avatar
Check the electrical connection on the trans for (greenies).
Old October 23rd, 2007, 11:00 AM   #4
Tom
Because racecar
Tom's Avatar
if it manually shifts fine it could also be the gov. pressure solenoid or transducer. does it struggle to move in D, or seem like its' trying to take of in the wrong gear? Also check the connector like killerb said, Then have the trucks ecm scanned for codes.
Old October 27th, 2007, 10:58 AM   #5
Shotgun
Shotgun's Avatar
trouble shot by trans guy and he said its a gear that locks the converter.
Old October 30th, 2007, 08:44 AM   #6
Tom
Because racecar
Tom's Avatar
ummmm... no gear locks the converter.... do you mean solenoid?
Old November 2nd, 2007, 01:09 PM   #7
Shotgun
Shotgun's Avatar
I will double check the info on this
Page generated in 0.18443 seconds with 44 queries
