Cover your rear - Great Lakes 4x4. The largest offroad forum in the Midwest
Old March 9th, 2006, 02:13 PM   #1
Grandman
do i look old !
Grandman's Avatar
Default Cover your rear
If your interested these cost me about 6 bucks each to make .
1/8 plate can be used for the base but if you happen to have an extra cover for your diff simple torch the outer bolt ring off and build onto that .
Used solid steel rod wich can be bent with a short piece of pipe and heavy hammer to mold the shape you want . Bolt the ring to the diff before welding on the cross parts to make sure the torch has not warped it . If you get done and it wont bolt on your screwed .
First bar tacked in place to make sure bolts still lined up .
Finished
Old March 11th, 2006, 12:55 AM   #2
Monkeyevil
I <3 Miatas
Monkeyevil's Avatar
Now instead of simply denting the diff cover you will break your dana 30 in half :tonka:
JcrOffroad
Zoom Zoom!
Old March 11th, 2006, 09:40 AM   #3
Grifter
Human Hunter
Grifter's Avatar
yeah......broken stuff.
grandman? so are you offering to make these for people? if so whats your price and do you limit your self to just D30's or more..heheheh
thanks...
Grifter
Grifter is offline   Reply With Quote
Old March 14th, 2006, 12:23 PM   #4
BMFmike
meh.
BMFmike's Avatar
Same question as the Grifter Gman
Thanks
Old March 14th, 2006, 09:02 PM   #5
Grandman
do i look old !
Grandman's Avatar
No just posting to show you guys how to make your own .
Old March 14th, 2006, 09:02 PM   #6
boggin-machine
boggin-machine's Avatar
could you jsut possibly weld on the little tubes on to the diff next to the bolt holes? would this work?? while it is on the axle?
Old March 15th, 2006, 09:15 PM   #7
Grandman
do i look old !
Grandman's Avatar
NO , you can pull the cover and do that . The dana 30 has a strong cover plate which would work well .
The rear one is a Ford 8.8 and is thinner . you could still weld to the cover ring but be careful to not burn thru .
Now DONT weld it up with it on the diff . Remove the cover or ground could pass through bearing rollers creating pits that would take out a bearing .
Old March 15th, 2006, 09:17 PM   #8
Grandman
do i look old !
Grandman's Avatar
If you have an old cover for your diff use it . cut the bolt on ring way from the round part . test fit this and grind as required to fit nicely . this will increase the strenght of the cover .
tack the cross bars on lightly and test fit again . then weld it solid is and easy way to build these .
Old March 15th, 2006, 09:18 PM   #9
boggin-machine
good thought.
never would have thought about that
Page generated in 0.25845 seconds with 50 queries
