Dana 35 Axle Shaft - Great Lakes 4x4. The largest offroad forum in the Midwest
Old October 21st, 2007, 11:04 AM   #1
TechJeeper
Formerly "Gr8archer"
TechJeeper's Avatar
Send a message via AIM to TechJeeper
Default Dana 35 Axle Shaft
So I have a bent axle shaft on my Jeep. I have a dana35 rear and I was woundering what is involved in changing an axle shaft on this axle? I know the front is pretty straight forward, how about the rear?
TechJeeper is offline   Reply With Quote
Old October 21st, 2007, 11:31 AM   #2
sglide
co captain of cubes pants
sglide's Avatar
search
this has been covered lots and lots and lots
sglide is offline   Reply With Quote
Old October 21st, 2007, 11:32 AM   #3
Motor Slut
I put the Ick in Dick.
Motor Slut's Avatar
The rear is easier...
Assuming you have a C-clip axle follow these steps
Remove the differential cover, take off the wheel and drum, bump the axle shaft inward, remove the c-clip, pull axle shaft out.
Old October 21st, 2007, 11:50 AM   #4
Buggy_Tim
(513) 891-8372
Buggy_Tim's Avatar
Pull cross shaft before bumping shaft and removing c-clip.
None of this applies if your axle is not a c-clip axle.
Old October 21st, 2007, 01:17 PM   #5
kickstand
circling the drain
kickstand's Avatar
avatar appears to be a TJ.
Assuming Dana 35 TJ c-clip remove diff cover, remove 1/4" bolt, remove cross shaft, bump axle shaft, remove c-clip, remove shaft.
Old October 21st, 2007, 05:21 PM   #6
TechJeeper
TechJeeper's Avatar
thank you, are there any bearings in the axle that need to be pressed or anything?
Old October 21st, 2007, 08:53 PM   #7
Nvrenuf
Nvrenuf's Avatar
Bearings are in the housing, not pressed on the shafts.
Page generated in 0.19335 seconds with 44 queries
