D44 Axle Upgrade... - Great Lakes 4x4. The largest offroad forum in the Midwest
Old October 19th, 2007, 08:23 PM   #1
jbro507
I <3 2get high.. centered
jbro507's Avatar
Default D44 Axle Upgrade...
Many of you chimed in a week or two ago when I asked about max tire size on my stock D30.. Now I'm wondering about the stock D44 out back.. I was thinking of picking up a SUPER44KIT with the ARB air locker from Superior Axle and Gear.. but I just found out how much it costs!
How big a tire can I go on my stock D44 *IF* I plan to stick in a locker.. Since the general consensus on my D30 question has me planning on going with 33's so I don't tear up my unlocked D30, will the stock axles in the D44 handle locked 33's?
Thanks to all the GL4x4 members for all your help...
jbro507 is offline   Reply With Quote
Old October 19th, 2007, 08:27 PM   #2
FlamesFearMe
Custom User Title
FlamesFearMe's Avatar
Ingersoll113 pounds a 37 on 44s, never had a problem.
4x Fanantic runs 39s on 44s, but his are souped up.
I personally would run a 37, but probably not much bigger. It really all depends on the abuse that it is going to see.
FlamesFearMe is offline   Reply With Quote
Old October 19th, 2007, 08:28 PM   #3
Toivo
Feel lucky?
Toivo's Avatar
Rear 44 is beefy enough for michigan, unless you want a lot of HP and <37s
Old October 19th, 2007, 08:30 PM   #4
Mclovin
"The Situation"
Mclovin's Avatar
Im gona run 38s on my 44's and ill upgrade shaft's etc as they break..
Old October 19th, 2007, 08:32 PM   #5
jbro507
jbro507's Avatar
I plan on getting my rig down to the badlands next summer... I had it at Paragon before we moved out here and want to get it back on some rocks.. so, the locked D44 on 33's will (hopefully) see some rocks..
Old October 19th, 2007, 08:33 PM   #6
FlamesFearMe
Custom User Title
I ran 33s on a locked 30/35 combo with no breakage down there. You should be fine with 33s on a 44.
Old October 19th, 2007, 08:35 PM   #7
Jeepaholic
Axle Guru Extraordinaire
Jeepaholic's Avatar
I got the 35 spline arb sitting here nib if you want some major beef
Old November 3rd, 2007, 11:17 PM   #8
C.K.
Dont Feed the Cyco
C.K.'s Avatar
I ran 38s locked front and rear on a D30 and D44 with stock shafts. Never broke a shaft yet.
C.K. is offline   Reply With Quote
Old November 4th, 2007, 12:16 AM   #9
sodapop
Support the Sport!
sodapop's Avatar
I think 37" would be safe but depending on your wheelin style you could prolly go as high as 38's. I plan on putting 37's on my front 44 and will upgrade to alloy shafts as they break.
Old November 4th, 2007, 06:10 AM   #10
You'll be totally safe running the 33's.
Old November 4th, 2007, 09:09 AM   #11
jmdzuk
jmdzuk's Avatar
Wheeling style? like never.Just pushing it out of the garage?
there are othert things to take into consideration ,wheel bearings ,brakes and the fact that he wants to lock it up.I would say 33'' and maybe 35'' if you you were smart on the trail ie. winch ,backup and don't ever say 1 more time (try) is the max for 30/44 combo for a trouble free summer of wheeling.
jeff
jmdzuk is offline   Reply With Quote
Old November 4th, 2007, 05:47 PM   #12
Cooter
Dad Kickin' It OldSkool
Cooter's Avatar
Shouldn't have any issue. I have never broken a 30 spline axle @ the Badlands with 34s to 36s in over 100 trips since they opened.
Your D44 will be fine with 33s
Page generated in 0.24306 seconds with 59 queries
