re-gearing - Great Lakes 4x4. The largest offroad forum in the Midwest
Old October 19th, 2007, 09:20 AM   #1
Lothos
KD8GKB
Lothos's Avatar
Default re-gearing
I'm setting up to re-gear my 03 Rubi and of course I have a bunch of questions that I can't find direct answers to even after reading through 15 pages in this section.
First off, gear ratio. Of the places I've glanced at online so far the highest I find is 5.13's. I'm still debating on whether my final tire size will be 35 or 37 and my worry is if I go with the 37's I don't know if 5.13 is enough. It's still my DD, but sees little to no highway use.
Second question: brand. I'm leaning towards the superiors right now since I've heard mixed luck with Yukon's and another brand.
Third: shafts. Some folks say upgrade the axle shafts and others say the rubi ones are ok with proper gearing. I had seen a year ago that folks were big into the new chromoly shafts for the 44. Is it necessary? If I actually did break one I would most certainly replace it with something stronger than stock as I just do that sort of thing.
Finally: since KB moved to Tenn, who else locally(Westland) does gear installs? I really don't want to take it all the way out to DTS.
Old October 19th, 2007, 05:08 PM   #2
KILLER"B"468
Yankabilly
KILLER"B"468's Avatar
Kevin at jeeperz creeperz is close to you. If you aren't going to drive to DTS than JCR is too far, but they do have the gas card option...
Go with Alloy shafts and the 5.13's will support both size tires.
Old October 19th, 2007, 05:23 PM   #3
Rubicon06
M-22
Rubicon06's Avatar
manual=4:88s
auto=5:13s
(rule of thumb)
FWIW, I too will most likely be upgrading to Alloy USA Chromoly axles with thicker splines and also re gear to 5:13s on my Jeep when I move up to 35s.
Rubicon06 is offline   Reply With Quote
Old October 19th, 2007, 07:29 PM   #4
Lothos
KD8GKB
Lothos's Avatar
Something like this?
was that a jab KB :)
I'll probably end up getting what I need from porc, but need an installer.
Old October 20th, 2007, 09:56 AM   #5
KILLER"B"468
Yankabilly
NOPE that was a right hook bitch!!!
Kevin or JCR give them a call
Old October 22nd, 2007, 01:05 PM   #6
Lothos
KD8GKB
Lothos's Avatar
I could switch to alloy shafts now right and swap gears later? I'm trying to time my gears so I do them shortly before swapping tires preferably. Although, 5.13's with 33's might be interesting :)
Also, Rubi stock 44's are 30 spline correct? I can't figure out if I should be looking at the 30 splines with no mention of locker or the ones that say come without locker. Is there a length difference I'm missing?
Old October 23rd, 2007, 06:27 AM   #7
Lothos
KD8GKB
Lothos's Avatar
bump
Old October 23rd, 2007, 09:57 AM   #8
Jeeperz Creeperz
GL 4x4 Vendors
Jeeperz Creeperz's Avatar
Yes, you can do the alloy shafts now and the gears later, but you'll be pulling the front shafts twice.
Rubicons are 30 spline inners. Any D44 locker would work, but you'd lose the factory air locker (obviously).
Old October 23rd, 2007, 10:08 AM   #9
Lothos
KD8GKB
Lothos's Avatar
I've pulled the front shafts i can't count how many times this year.
I don't plan on removing the OEM lockers. My concern was specifically which part # I should be looking at. There are both 30 and 33 spline 44's with and without lockers and with no mention of a locker at all. Is the part # for the shafts without locker the same as the shafts with no mention of a locker at all?
Old October 23rd, 2007, 11:09 AM   #10
Jeeperz Creeperz
GL 4x4 Vendors
The 33-spline options are for upgraded shafts. The stock spline is 30, but if you're thinking about doing a shaft upgrade to a 33-spline then you'll have to replace the factory lockers.
Normally the shafts are one part number and the shafts with locker is another part number.
Jeeperz Creeperz, Inc.
1627 Eureka Rd
Wyandotte, MI 48192
734-281-8141
M-F 10am-7pm
Sat 10am-3pm
www.jeeperz-creeperz.com
Old December 26th, 2007, 11:32 AM   #11
joe_jeep
welfare wheeler
joe_jeep's Avatar
the rubi d44 is 27 spline outers. if your gonna do alloy shafts think about 30 spline outers too. all you need is 30 spline stubs and 30 spline unit bearings. superior sells a kit, alloy might too. you could keep the old stubs and units as spares, but they need to be replaced together. good luck
Page generated in 0.32998 seconds with 56 queries
