TONS of XJ/YJ/CJ Parts-swing out, axle, cage + MORE - Delivery Path Added - Great Lakes 4x4. The largest offroad forum in the Midwest
Old October 18th, 2007, 04:26 PM   #1
Buggy_Tim
(513) 891-8372
Buggy_Tim's Avatar
Default TONS of XJ/YJ/CJ Parts-swing out, axle, cage + MORE - Delivery Path Added
ALL UPDATES WILL BE IN THIS FIRST POST
Yes, it is time. MuddyPaws is being re-born in another vehicle. Many of the parts on this rig will live on in MuddyPaws2 but lots of this stuff must go.
MAKE ME SOME OFFERS!
Need This Stuff Sold Off For New Build!
FREE Delivery to the Detroit area November 21-25.
Axles, wheels, tires, CO2, motor - NOT FOR SALE
TRADES:
XJ rear bumper
XJ rocker guards
XJ tail light conversion to LED
2 inch, 5 on 4.5 wheel spacers
XJ Cage
XJ Rock Sliders
Staun Internal bead locks for 15x8 rim
Beadlock Rims 15 inch
TJ D30 Axle Shafts - Inner and outers (need 2 sets)
I LOVE Pay-Pal.
Make Some Offers, I Need This Stuff Sold
Delivery to the Detroit Area will happen November 21st through 25th.
This is the route I will be taking to head down state. Same way on the way back. During the in-between time, I can meet you if it's worth the gas to do so.
Shipping is available on your dime for some of the smaller stuff. Nothing will be considered sold unless payment has been made.
Pictures of all the stuff can be found HERE
If you see something you want that isn't listed, ask about it.
Stuff for sale at this time:
Prices OBO
87 YJ Tub and Frame. Tub rusty but still has solid spots. Hood Good, Windshield frame good but glass is pitted on the inside (still usable, just a slight bother), stainless hinges. Rear of the frame behind wheels and rear crossmember has been replaced. Grill good, has buckets but no trim. Rear tailgate good but missing inside cover over latch stuff. Everything painted with durabak. No steering column. Most of the dash is there. Comes with oil, temp, volts, gas aftermarket gauges. - Make Offer
YJ D30 - 4.10 Gears - $150
Complete caliper to caliper. Vac-Disco Axle.
Newer unit bearings. Newer rotors.
Flaming River Steering Shaft for YJ - $40
Good shape, has rebuildable ends.
YJ (maybe others) Steering Gear - $35
NAPA part. Less than a year old
YJ (maybe others) Drop Pitman Arm - $20
Can ship for 5 bucks more if done with Pay-Pal
Howell TBI Fuel injection for Chevy 350, reprogrammed prom, complete with temperature sensor, throttle body with IAC, TPS, and injectors, small cap distributor, coil, MAP sensor, oxygen sensor, knock sensor, wiring harness, computer (ECM), fuse box, TBI adapter plate, in-line fuel pump - $450
http://www.howellefi.com/shop/customer/home.php?cat=252
Or-Fab Swing Away Tire and Gerry Can Carrier - $150
Bracket has been moded to allow LED light. See Pics. Can and High Lift not included. Lost wing nut for can hold down, I use a ratchet strap now.
http://www.quadratec.com/products/12045_312_07.htm
Older Best Top 2 piece soft doors - $50
Not pictured but in pretty good shape. Black denim. Driver's door has a small crack in the window that is stuck together with black duck tape. Clean up nice.
Best Top Safari Top - $40 SHIPPED
Like new condition. This is a strapless top that goes from the front, all the way to the back. CJ/YJ no windshield track. Must have family roll bar or full cage.
Pics of top:
http://www.timstrader.com/web/jeep/y...sc/safari1.jpg
http://www.timstrader.com/web/jeep/y...sc/safari2.jpg
2 Wheel Drive AW4 out of 1995 XJ - $100
Out of 4.0 vehicle. Good shape, shifts, complete with converter. Needs output seal.
2 XJ Rear Driveshafts -
One 2 wheel drive, one four wheel drive
Your Choice $30 each
Full Set, D30 Axle Shafts (all 3 pieces)
Great for spares - $50
SALE PENDING - cannaert
OR-Fab Sport Cage - $150
Complete bolt in front OR-Fab set-up with 2 streamers.
SALE PENDING - jvh025
Dual Fan Setup - $30
Chrysler LHS dual fan
Off Road Rocker Switches (3) - $20
Fuel (on-off), fans (2 speed), Spot lights (2 position)
SALE PENDING - sandmaster
4 inch Soft Ride Lift Springs - $200
Just the Springs, no shocks. GREAT ride quality. Super flexy and soft.
SALE PENDING - BIGDANE36
OR-Fab Front Bumper - $150
Drilled for tow bar.
OR-Fab Rear Bumper - $150
SALE PENDING - bbaXJ
Winch Plate - $25
3/8 inch thick angle type with tow hooks.
SOLD - Gunsworth
Home Made Tube Fenders With Flare - $150
Sprayed with duplicolor bed liner. Retains inner fender, very stout. All 1/8 plate.
SOLD - Skooter_Built
2 Wheel Drive 1995 XJ Front Axle - $50
Knuckle to knuckle. No brakes.
SOLD - 99grandtj - $175 shipped
Novak NP231 Shifter Assembly - The billet knob that you see in the link below is not included....I didn't order that.
Mojave Heater with Plenum -
Includes 3-way switch & wiring, 12,000 BTU output. Comes with custom vent setup. See pics.
DELIVERED
SOLD - Local
Hard Doors - $100
Complete with all glass and hardware, no rust. After market door pulls. Doors were CJ doors and were cut to allow the YJ vent window use...but the passenger side was not cut very well. See pics. Sprayed with black duplicolor bed liner.
DELIVERED
SOLD - ladiekilla04
Home Made Rocker Guards - $50
Little rust, need paint. Either 1/4 or 5/16 plate.
DELIVERED
SOLD - DeltaCavXJ
NEW - 3 inch Rough Country XJ Lift -
New kit, installed but not one single mile put on it. Comes with front springs, all shocks, rear AAL and u-bolts.
31 10.5x15 Sport King AT's
Tires have a little checking but still very usable. Even wear but 2 have a little less tread than the other 2.
DELIVERED
SOLD - Mongo
Best Top Bikini Top - $25
Like new condition. This is a strapless top that covers the front only. CJ/YJ no windshield track.
DELIVERED
SOLD
California Tops Soft Top - $100
Almost frameless. Easy to put up. All hardware included. Tinted windows. Slight scuff on passenger side, small rip on driver's side. See pics. Windows good, passenger side window zipper got a little mucked up so it was stitched together. Can't remove the window now.
DELIVERED
SOLD - jeepguy74
B&M Z Gate Shifter for Chevy TH350
Plastic trimmed to fit my app but you can buy new ones. Good shape, complete with cable and brackets.
http://store.summitracing.com/partde...;2D80681&N=700 +400004+4294822068+115&autoview=sku
TH350 mated to a NP231
Great shifting TH350 with shift kit, NP231 driver's drop, Perfect for a small block chevy install. Mechanical Jeep speedo hole. Complete with converter.
Chevy Conversion Radiator
Will need the top neck soldered properly...maybe. Last spring it leaked on the trail and I JB'd it and it hasn't leaked since but would need soldering to fix it right.
Lots of Misc stuff
Old October 18th, 2007, 04:41 PM   #2
user name
keep your stick onthe ice
user name's Avatar
I can deliver to the big rapids area for gas money if anyone wants stuff on the west side.
Old October 18th, 2007, 04:42 PM   #3
Buggy_Tim
(513) 891-8372
Buggy_Tim's Avatar
Thanks Craig.
Old October 18th, 2007, 04:45 PM   #4
Jeepaholic
Axle Guru Extraordinaire
Jeepaholic's Avatar
Would you ship the heater? If so how much to 48867?
Seperate the t case shifter?
Old October 18th, 2007, 05:04 PM   #5
Buggy_Tim
(513) 891-8372
Buggy_Tim's Avatar
Yes, I can ship that. Be about 10 bucks.
Shifter has been slightly modded to fit this mating of 231 and th350 but could easily be un-modded to fit just about any 231. Separate it for 60 bucks and toss it in the box with the heater for 5 bucks more.
Old October 18th, 2007, 05:49 PM   #6
Mongo
Mongo's Avatar
Tim, if username can drop at marvs, I can get stuff to the east side.
edit:Craig & Craig deliveries:tonka:
Mongo is offline   Reply With Quote
Old October 18th, 2007, 06:40 PM   #7
Trail Junkie
iamfawkinwithyou
Trail Junkie's Avatar
Think the fenders would fit a cj???, I to can get stuff down state for ya
Old October 18th, 2007, 07:13 PM   #8
Buggy_Tim
(513) 891-8372
Buggy_Tim's Avatar
That I don't know. Will YJ fenders fit a CJ? These bolt to the stock fender holes.
Old October 18th, 2007, 07:40 PM   #9
Jeepaholic
Jeepaholic's Avatar
Sending PM
Old October 18th, 2007, 08:40 PM   #10
Toivo
Feel lucky?
Toivo's Avatar
I will deliver anywhere along I75/US23 from Sault Ste Marie to Ann Arbor for gas money as well.
Old October 18th, 2007, 09:01 PM   #11
Tie Dyed
O.G.
Tie Dyed's Avatar
Send a message via AIM to Tie Dyed
Tim-
did you want to sell the th350/231 as a whole unit? If not, pm me a price on the 231.
Thanks
2000 XJ with a 3 inch body lift
Tie Dyed is online now   Reply With Quote
Old October 18th, 2007, 09:23 PM   #12
Buggy_Tim
(513) 891-8372
Buggy_Tim's Avatar
Originally Posted by Tie Dyed View Post
Tim-
Thanks
Tie, the 231 won't really do you much good. It is designed to be mated to this setup. The front half of the case is a 231c and the back half is 231j. So if you had the tcase, you can't put it in a jeep unless you put it on a th350 with the adapter that it comes with. I am separating the shifter so the price has dropped.
Old October 18th, 2007, 09:26 PM   #13
Tie Dyed
O.G.
Tie Dyed's Avatar
ahh, but would it work behind my th400?
Old October 18th, 2007, 09:44 PM   #14
Buggy_Tim
(513) 891-8372
Buggy_Tim's Avatar
:miff:
I don't know.....is the output housing bolt pattern for the 4x4 th350 the same as the 4x4 th400? Is the output shaft of the 2 the same size and spline?
Like i'm some sort of cross reference guru.
Old October 18th, 2007, 09:46 PM   #15
ddeadserious
ddeadserious's Avatar
Could you get me a pic and some measurements of the fan?
ddeadserious is offline   Reply With Quote
Old October 18th, 2007, 09:52 PM   #16
Buggy_Tim
(513) 891-8372
Buggy_Tim's Avatar
Sure...
Pictures of Everything
I'll have to get a measurement.
Old October 18th, 2007, 09:54 PM   #17
Hacksaw
WWSD - What would stan do
Hacksaw's Avatar
:miff:
TH350 = 27 spline
TH400 = 32 spline
Old October 18th, 2007, 10:03 PM   #18
Buggy_Tim
(513) 891-8372
Buggy_Tim's Avatar
Originally Posted by HackSaw View Post
TH350 = 27 spline
TH400 = 32 spline
Well there you go.
You don't want that crappy th400 anyway Tie.:tonka:
Old October 18th, 2007, 10:11 PM   #19
Mongo
Mongo's Avatar
Sending PM
Tim,
If you are going to Marv's Halloweiner Party on the 26th, I can deliver to Adam.
Old October 18th, 2007, 10:16 PM   #20
Buggy_Tim
(513) 891-8372
Buggy_Tim's Avatar
Originally Posted by Mongo View Post
Tim,
I won't be able to make the party....the wife has to work that weekend in Escanaba so I am on daddy duty.
But thanks.
Page generated in 0.66329 seconds with 83 queries
