Ford Ranger - Great Lakes 4x4. The largest offroad forum in the Midwest
Old October 16th, 2007, 08:37 PM   #1
Ranger88
Ranger88's Avatar
Default Ford Ranger
Does anyone know where the breathers are located in a 1989 ford ranger?
thank you very much,
i need to know so i can reroute them,
Ranger88 is offline   Reply With Quote
Old October 16th, 2007, 08:39 PM   #2
88mudder
In the band!
breathers? plz explain a little more
Old October 16th, 2007, 08:40 PM   #3
trans?
the frt diff is right by the pass side axle shaft, the stock breather tube is like a question mark shape, and obviously the rear breather is on the axle tube i beleive drivers side. the tcase it just above and to the left of the driveshaft for the front axle
Old October 16th, 2007, 08:51 PM   #4
Captain Ledd
Ranger Addiction?
Captain Ledd's Avatar
I can't think of the one for the trans either...
I pulled them all out of the different drivetrain I have now, tapped the holes (don't get shavings in there, I took the tranny and T-case apart just barely enough to ensure I didn't) and replaced them with hose barbs, a couple 90° fittings wouldn't hurt either.
Last edited by Captain Ledd; October 16th, 2007 at 09:03 PM. Reason: "different" added.
Old October 16th, 2007, 09:17 PM   #5
Ranger88
Ranger88's Avatar
thank you all very much, i will look into this tomorrow morning, im going to the mounds on saturday, so i wanted to make sure i was alright
Old October 16th, 2007, 10:30 PM   #6
chris1044
chris1044's Avatar
IIRC the A4LD and M5OD BOTH do have breathers....the M5OD is a little metal nub (not as big of a deal though as it's a stick) and the A4LD has a hose that routes into the engine bay and then loops back down onto the bell housing (atleast mine did and it's a 94.....part of the "hose" is a metal piece)
Maybe I'm crazy though, but I'm pretty sure it does have one
Keep in mind that if any of your components is leaking fluid out anywhere (axle seals, output shaft seal, etc) that water CAN get in there as well......just a thought
Old October 25th, 2007, 06:47 PM   #7
88fordman
88fordman's Avatar
part of the metal line on that trans breather has holes drilled into it for air expansion. if left for long enough water will run down into the line. then just stir and you got yourself a strawberry milkshake :)
I ripped mine off and ran hose WAAAAY up into the engine bay. then you can just top them off with a small engine fuel filter to help keep any crud outta there. thats what I did anyway. good luck!
88fordman is offline   Reply With Quote
Page generated in 0.32631 seconds with 44 queries
