timing chain cover gasket - Great Lakes 4x4. The largest offroad forum in the Midwest
Old October 15th, 2007, 08:16 PM   #1
vwBOY
it's how i roll
vwBOY's Avatar
Default timing chain cover gasket
so on my 1994 f-150 the timing chain cover gasket is leaking right were one of the passage ways for the coolent is and i tore it down but there is a stuberen bolt behind the crank pulley the i can get to with an open end wrench but the bolt is in there good and i dont want to round the bolt off so any suggestions would be great
vwBOY is offline   Reply With Quote
Old October 15th, 2007, 08:37 PM   #2
Bones
Bones's Avatar
buy a good set of box wrenchs?
Inviscid Motorsports
Motorcity Machines
Branik Motorsports
Maxxis Tires
Raceline Wheels
PAC Racing Springs
Joint Clutch and Gear
Old October 15th, 2007, 11:44 PM   #3
Wallybob
Wallybob's Avatar
I think you are going to have to remove the pulley and damper to remove the cover. After you get that off it should be easy to get to.
Wallybob is offline   Reply With Quote
Old October 16th, 2007, 08:05 AM   #4
Hackfabrication
Hack
Hackfabrication's Avatar
What he said ^...If the leak is between the timing cover and the block, you're going to have to pull the balancer to remove the timing cover. When you get the gasket kit it will have a new crank seal. Do it right, and replace your old one when you put it all back together. Torque wrench is your friend.
Ford also had a habit of using Metric head fastners with SAE threads (5/16-18) on certain areas. I can't recall the exact size (IIRC 10mm?), but I replaced all of mine with ARP products. Except for the two 'special' bolt/studs used for accessorie mounting:
Of course, it's much easier to do with the motor out of the vehicle .
Hackfabrication is offline   Reply With Quote
Old October 16th, 2007, 09:02 AM   #5
bj house
bj house's Avatar
Hack Fab no more pictures of your garage. It is way too clean and your compressor could be a little larger :tonka:
Page generated in 0.31741 seconds with 38 queries
