amc 20 - Great Lakes 4x4. The largest offroad forum in the Midwest
Old October 15th, 2007, 06:41 AM   #1
nvr-enuf-money
Old Hippie
nvr-enuf-money's Avatar
Default amc 20
I bought a d44 and a amc 20 for my yj. Are there any problems with the 20? Is it better than a d35? Thanks
nvr-enuf-money is offline   Reply With Quote
Old October 15th, 2007, 06:45 AM   #2
hawkscj5
Skinny Pedal Crawler
hawkscj5's Avatar
solid shafts(one piece) is a must!
hawkscj5 is offline   Reply With Quote
Old October 15th, 2007, 06:50 AM   #3
nvr-enuf-money
Old Hippie
They are from a 75 wagoneer, I think they are solid shafts, but I don't have them home yet
Old October 15th, 2007, 10:46 AM   #4
xj_man_646
Wheeler-less
xj_man_646's Avatar
Send a message via AIM to xj_man_646
waggy = solid shafts and thicker tubes. very good axle IMO. stronger than a d44 too. paper thin stock diff cover, i suggest replacing it. rear disc conversion can be done with the front 44 brake rotors/calipers/caliper brackets. I run one, and have yet to do anything harmful to it. I run it 4.10's and welded on 36" TSL's.
xj_man_646 is offline   Reply With Quote
Old October 15th, 2007, 01:07 PM   #5
nvr-enuf-money
Old Hippie
Thanks guys
Old October 15th, 2007, 03:25 PM   #6
scorpio_vette
scorpio_vette's Avatar
Send a message via MSN to scorpio_vette Send a message via Yahoo to scorpio_vette
that's all there is to it, or what are the "fine details"???
scorpio_vette is offline   Reply With Quote
Old October 16th, 2007, 03:16 PM   #7
xj_man_646
Wheeler-less
xj_man_646's Avatar
from what I have read, the only 'tricky' part is getting the caliper brackets to fit properly, seeing as they are meant to bolt onto the knuckle.
Old October 22nd, 2007, 10:04 PM   #8
Fraser
Fraser's Avatar
X2
Old October 23rd, 2007, 11:49 AM   #9
Hackfabrication
Hack
Hackfabrication's Avatar
AMC20 out of a FSJ is way better than the CJ version. As stated, heavier tubes and one piece axles. Lots of options for disc brake conversions. The diff cover is a thin POS. You'll need to construct some sort of guard to protect it.
Hackfabrication is offline   Reply With Quote
Page generated in 0.27274 seconds with 50 queries
