93 E350 5.8 no start - Great Lakes 4x4. The largest offroad forum in the Midwest
Old October 14th, 2007, 12:10 PM   #1
jmdzuk
jmdzuk's Avatar
Default 93 E350 5.8 no start
I just bought a 93 van 5.8 liter ran great on the way home .
It stumbled a little when I started it but cleared right out ,The seller said he put new plugs in but they were cheap plugs and would change them .
We put 50 some miles on it yesterday ,stopped put gas in it and went home this morning its a no start cranks great just no fire .
Things I checked so far
Turn key to on I can here the fuel pump build psi then kick out turn the key to start just cranks
fuel inercha (sp) switch has not been tripped
does not smeel of gas at the tail pipe ? or allot I would think as much as I cranked it if it was getting fuel it would be pretty bad
fuse for fuel pump is good .
It has a alarm system on it I didnt mess with it at all .but could be suspect
it does sputter once in a wile after it has been cranking
Jeff
jmdzuk is offline   Reply With Quote
Old October 14th, 2007, 12:35 PM   #2
Bones
Bones's Avatar
do you own a timing light to check spark?
Inviscid Motorsports
Motorcity Machines
Branik Motorsports
Maxxis Tires
Raceline Wheels
PAC Racing Springs
Joint Clutch and Gear
Old October 14th, 2007, 12:38 PM   #3
jmdzuk
jmdzuk's Avatar
yes
Old October 14th, 2007, 12:54 PM   #4
jmdzuk
jmdzuk's Avatar
has spark
Old October 14th, 2007, 01:03 PM   #5
beejers
always building
beejers's Avatar
Spary some starting fluid in it to see if it fires, if it doesnt i would say a fuel problem. may have a lack of pressure.
beejers is offline   Reply With Quote
Old October 14th, 2007, 01:13 PM   #6
jmdzuk
jmdzuk's Avatar
Thank you! He ran to the gas station to get the fluid to check. Let you know what happens.
Old October 14th, 2007, 01:25 PM   #7
jmdzuk
jmdzuk's Avatar
Did not work! Fuel Pump?
This is Busbabe by the way, I'm replying while He's outside.
Old October 14th, 2007, 01:29 PM   #8
jmdzuk
jmdzuk's Avatar
I sprayed starting fluid in and nothing /no fire
Old October 14th, 2007, 01:29 PM   #9
beejers
always building
beejers's Avatar
didnt fire? = not a fuel problem
check spark. take out one of the easy plugs and look for spark.
Old October 14th, 2007, 01:33 PM   #10
jmdzuk
jmdzuk's Avatar
Did that has spark ,then I sprayed starting fluid to rule out a fuel delivery problem.
I wonder if there is a interlock ,that certain events have to be meet to fire.?
Old October 14th, 2007, 01:36 PM   #11
beejers
always building
beejers's Avatar
did you check with the plugs that are in it or with the timming light?
Did you, after the starting fluid was sprayed, hit the throttle? some of the throttle bodies wont let anything past it unless you depress the throttle.
Old October 14th, 2007, 01:40 PM   #12
jmdzuk
jmdzuk's Avatar
good point on throttle Ill check it right now .
I pulled a plug wire off and stuck anther plug on it grounded to block .
THANKS Jeff
Old October 14th, 2007, 01:45 PM   #13
jmdzuk
jmdzuk's Avatar
THANKS Jeff
didnt work starting fluid out tail pipe
Old October 14th, 2007, 01:50 PM   #14
beejers
always building
beejers's Avatar
pm'd ya
Old October 14th, 2007, 01:53 PM   #15
hawkscj5
Skinny Pedal Crawler
hawkscj5's Avatar
mmmmmmmmm timing chain out???? just a thought.
hawkscj5 is offline   Reply With Quote
Old October 14th, 2007, 08:17 PM   #16
jmdzuk
jmdzuk's Avatar
pm'd ya
Thanks guys got it running turned out it was the coil .It had spark but week.New plugs and coil wala.....
Thanks again Jeff
Page generated in 0.21210 seconds with 71 queries
