7.3 PSD: Help please - Great Lakes 4x4. The largest offroad forum in the Midwest
Old October 13th, 2007, 02:45 PM   #1
HVYRTFT
Reed my teef
HVYRTFT's Avatar
Default 7.3 PSD: Help please
Someone school me on diesels.
What are some general guidlines for prevenative maintenance for diesels? What needs special attention? Etc. Etc.
It's a 99 7.3 PSD 4x4 with 160k
Old October 13th, 2007, 04:34 PM   #2
HVYRTFT
Reed my teef
HVYRTFT's Avatar
no one knows about diesels eh?
Old October 13th, 2007, 04:39 PM   #3
bigcountrysg
Countryboy
bigcountrysg's Avatar
not to take away from this site but, www.powerstroke.org is a great site for the PSD's.
I have a 2002 7.3L I have 154,000 and I just follow the maintenance guidlines in the owners manual. That is for the routine maintenance.
bigcountrysg is offline   Reply With Quote
Old October 13th, 2007, 04:42 PM   #4
HVYRTFT
Reed my teef
HVYRTFT's Avatar
It would be hard to follow the owners manual because I am not an owner. That's why I'm looking to PSD owners for things to look for as a prospective buyer
Old October 13th, 2007, 04:45 PM   #5
GNJEEPN
Grumpy Grampa
GNJEEPN's Avatar
Check and change the oil reg. Change fuel filter reg. Do normal cooling system flushes. When to do these depends on how you use your truck. I change my oil about every 7500 miles. Fuel filter twice a year. Cooling system every 3 years. You might also want to run some fuel conditioner once in a while. I carry anti gel additives in the winter. You might also want to carry a spare crank sensor as they have been know to fail and leave you stranded. I have only had one fail in 130,000 miles.
GNJEEPN is offline   Reply With Quote
Old October 13th, 2007, 04:51 PM   #6
bigcountrysg
Countryboy
oil change every 5,000 miles, fuel filter every 10,000 miles, air filter every 10,000 miles, trans fluid every 30,000, diff fluid every 75,000, coolant flush every 30,000, in cab air filter if applicable every 30,000 miles. I hope this helps you out.
I have 154,000 miles on my truck the only major problems I have had is the transmission. But then again when you abuse them they break.
GNJEEPN that would be Cam Position Sensor (CPS) and yes I have a spare in my glove box with the 1/4 inch drive ratchet 6 inch extension and 10 mm socket. Because that is all that is needed to use to replace this sensor.
Old October 13th, 2007, 04:59 PM   #7
GNJEEPN
Grumpy Grampa
GNJEEPN's Avatar
Yep your right I'm bad. Oops
Old October 13th, 2007, 05:02 PM   #8
GNJEEPN
Grumpy Grampa
GNJEEPN's Avatar
Keep in mind the 7.3PSD takes 12qts of oil when you change it.
Old October 13th, 2007, 05:18 PM   #9
xj4life
xj4life's Avatar
yup they're hungry son of a bitches
i've had my 99 for a year and a half now and love it. as stated already as long as you keep up on regular maintance they're great motors.
Old October 13th, 2007, 05:21 PM   #10
HVYRTFT
Reed my teef
HVYRTFT's Avatar
awesome. this is what I was looking for. And should I shy away from one with said mileage? And what should I expect for MPG empty? Thanks!
Old October 13th, 2007, 06:10 PM   #11
bigcountrysg
Countryboy
You better add another 3 quarts to that 12 to make 15 quarts. As that is what mine takes every oil change.
Old October 13th, 2007, 06:13 PM   #12
bigcountrysg
Countryboy
O average 21-22mpg with my everyday driving. Mileage on a diesel is not that bad. If I was looking for a new used truck I would be looking for around 100,000 miles with not alot of major maintenance. Being your looking at the 7.3L that would not be to hard to find. Now if it was the 6.0L that would be a different story as the 6.0L had issues with the EGR cooler, EGR valve and turbo.
Old October 14th, 2007, 06:29 AM   #13
GNJEEPN
Grumpy Grampa
GNJEEPN's Avatar
Yes again you are correct sir. I have to slow down when I am typing.
Old October 14th, 2007, 06:32 AM   #14
GNJEEPN
Grumpy Grampa
GNJEEPN's Avatar
I get very close to these numbers also with out a load. Drops to about 18 to 19 when I have the camper in the bed and towing my car hauler with the Jeep on it.
Old October 14th, 2007, 07:48 PM   #15
bj house
bj house's Avatar
I have had a 02 F250 7.3L and now an 02 Ex 7.3L. I do what he said,
Plus vist www.thedieselstop.com they have answered every question that I have had so far. Front axles like to eat ball joints and wheel bearings but if you do the work yourself it is not that painful. I have done pads and rotors on both of my trucks as well. Turn the factory ones before they get two bad they are not very thick anymore.
Old October 14th, 2007, 10:14 PM   #16
HVYRTFT
Reed my teef
HVYRTFT's Avatar
the good thing about this truck is the ball joints are shiny new.
Old October 15th, 2007, 08:58 AM   #17
GNJEEPN
Grumpy Grampa
GNJEEPN's Avatar
I put new greasable heavy duty ball joints in mine about 70,000 miles ago. I haven't had any problems since. I grease them regularly with the weight off the joints.
Page generated in 0.59633 seconds with 74 queries
