electric choke - Great Lakes 4x4. The largest offroad forum in the Midwest
Old March 7th, 2006, 06:37 PM   #1
Arnie897
y=mx+b
Arnie897's Avatar
Send a message via AIM to Arnie897
Default electric choke
Just installed a Holley Truck Avenger in my Jeep. The engine is a AMC 360.
Where do you hook the electric choke wire up to and how exactly does electric choke work? It was suggested to find a 12v source....but which one? I was running a carb with a manual choke setup and I'm clueless to these new fangled electrical things.
Arnie897 is offline   Reply With Quote
Old March 7th, 2006, 06:54 PM   #2
Yetti
Buy a Fiat! Save the UAW!
Yetti's Avatar
it need to go to switch power on the ignition side of the key. if not it could stay powered up when the power is supposed to be off. and don't wire to the accessory side either
Yetti
Old March 7th, 2006, 08:27 PM   #3
BigBlkYJ 355
U-Joints Fear Me
BigBlkYJ 355's Avatar
Electric choke works by heating an element up which over like 1 minute will open the choke butterfly. Power to the choke must be on all the time when the motor is running.
Old March 7th, 2006, 08:32 PM   #4
shawn
Resident HVAC/R Jambi
shawn's Avatar
Originally, the Choke on jeeps s powered through a switch on the same manifold as the oil pressure sender. It would power up the choke when you have oil pressure, when the motor is actually running. If you have a factory or aftermarket wiring harness you will have the wire there to hook to the choke. Or, look to see if you have that switch down by the oil sender, it will have 2 wires comming off of it. Maybe trace it from there.
Page generated in 0.14295 seconds with 35 queries
