Ford 4wd & Factory Lockout Problem - Great Lakes 4x4. The largest offroad forum in the Midwest
Old October 10th, 2007, 02:11 PM   #1
83K5fullsize
Drew
83K5fullsize's Avatar
Default Ford 4wd & Factory Lockout Problem
Have a problem with my 4wd working sporadically on my 2001 F250 tow rig. No rime or reason to when it will & won't work. When I turn the knob to 4x4 the "4x4" light will come on & I can hear something shift from the transfer case like it's always done, but sometimes no power to the front end & sometimes there is.
Any suggestions, or anyone had the same/similar problem & fixed it ??
Have had the hubs in auto position sense I bought it 4 years ago and the 4wd has always worked. Like most of these Fords the manual hub is frozen in the auto position. I thought perhaps I could easily eliminate the hubs as the problem the next time the 4wd didn't work by manually locking them in but I can't turn them from auto.
I've never even had the wheels off this thing so I'm not sure what these hubs are like or what it's going to take to free them up. Can you free them up ? Any secrets to what it takes to do so ? I plan to pull them apart this weekend to take a look at them but wanted some input from anyone that has some experience with them. I've had my Warns a part on my Blazer many times but don't know it these factory auto hubs are similar.
Any help & input would be greatly appreciated.
83K5fullsize is offline   Reply With Quote
Old October 10th, 2007, 04:09 PM   #2
Jeeperz Creeperz
GL 4x4 Vendors
Jeeperz Creeperz's Avatar
Bad hubs. Common problem.
Old October 10th, 2007, 06:30 PM   #3
broncobuddha
Starting over
broncobuddha's Avatar
Send a message via AIM to broncobuddha
Yessir, the auto hubs on ford trucks are notorious for this. first they are sporadic then they stop working altogether.
broncobuddha is offline   Reply With Quote
Old October 11th, 2007, 12:12 PM   #4
bender
Your daily fullsize fix.
bender's Avatar
Send a message via AIM to bender Send a message via MSN to bender Send a message via Yahoo to bender
yep. i just replaced mine too. a little bit different since my tcase is manual, but same factory junk.
go Warn... i got the premiums for less than $200 for both w/ lifetime warranty. they're not auto, but you can depend on them at least.
bender is offline   Reply With Quote
Old October 11th, 2007, 03:45 PM   #5
Troll53
Lurker under the bridge
Troll53's Avatar
Send a message via MSN to Troll53
It could also be the vacuum actuator or the vacuum/hub seals...
Troll53 is offline   Reply With Quote
Old October 12th, 2007, 10:31 AM   #6
83K5fullsize
Drew
Was thinking of going to a set of Warns and just doing the manual thing. I'm fine with that as it's my tow rig & is rarely in 4wd. But when I need it I want it to work.
What all was involved in changing to the Warns ? I thought I heard there was a kit or something needed in addition to the Warn hubs for them to be compatable.
Old October 12th, 2007, 10:50 AM   #7
Jeeperz Creeperz
GL 4x4 Vendors
Just remove OEM hubs and throw in trash, insert Warn/Mile Marker body and install snap ring, bolt cover on to that and you're done.
Jeeperz Creeperz, Inc.
1627 Eureka Rd
Wyandotte, MI 48192
734-281-8141
M-F 10am-7pm
Sat 10am-3pm
www.jeeperz-creeperz.com
Old October 12th, 2007, 11:54 AM   #8
83K5fullsize
Drew
PM'ed you before I saw your reply. Sorry. Thanks for the info. Sounds pretty stright forward. I'm going to be pulling it apart this weekend I hope. Want to get it done before I head to Iowa on a hunting trip in a few weeks.
Thanks again for your help !
Page generated in 0.20771 seconds with 47 queries
