Switching 9" carriers for DD - insanity? - Great Lakes 4x4. The largest offroad forum in the Midwest
Old October 9th, 2007, 02:29 PM   #1
jbro507
I <3 2get high.. centered
jbro507's Avatar
Default Switching 9" carriers for DD - insanity?
Is this insane or does it make sense.. Say you wanted nice low off-road gearing for your DD but diden't want to sacrifice gas miliage - if you had a 9" in the rear, you could have two carriers - one loaded with low off road gears (that match the front axle's) and one loaded with a higher street gears for DDing in 2wd?
If you wheel monthly, would it be worth all the work switching them to save (?) some dino juice.
jbro507 is offline   Reply With Quote
Old October 9th, 2007, 02:43 PM   #2
Sounds like a waste to me, unless you really had a long way to drive. Anything that needs that big of gearing difference is going to suck gas down anyway...
If you were to do it, at least get full float setup to make it quicker to pull the axles.
But it'd be a waste.
Old October 9th, 2007, 04:26 PM   #3
Doesn't make sense to me. A lot of work, draining oil, stripping bolts, etc.
Old October 9th, 2007, 04:35 PM   #4
Blackjackbender
if you dont have a OD tranny i think id swap one in before id switch a 9" carrier
Old October 9th, 2007, 05:14 PM   #5
Cooter
Dad Kickin' It OldSkool
Cooter's Avatar
I have done it with my 8 3/4 in the TJ- pretty easy, and the open diff is much less annoying than the spool on the street w/o swaybars. :tonka:
Used to drive up to Great Lakes Dragaway in Union Grove with 3.23s in my old Challenger, and swap 4.88s in at the track. I could drop the exhaust, swap on slicks and change the rear diff in 20 minutes or less.
Old October 9th, 2007, 06:58 PM   #6
All by yourself?
Old October 10th, 2007, 05:51 AM   #7
95geo
newbie
95geo's Avatar
I want you to do it once, I bet you will never consider the idea again.
Old October 10th, 2007, 05:00 PM   #8
hosejockey4506
Visiting Admin
hosejockey4506's Avatar
:miff: :miff:
hmm i must be slow i can only do that in 22 minutes
Old October 10th, 2007, 06:59 PM   #9
sglide
co captain of cubes pants
sglide's Avatar
x2
sglide is offline   Reply With Quote
Old October 10th, 2007, 07:48 PM   #10
Fullsize4life
Kicking Cancers ASS
Fullsize4life's Avatar
Just buy a tow rig and trailer. That shit sounds like work when you should be wheeling
Old October 10th, 2007, 08:45 PM   #11
Cooter
Cooter's Avatar
All by yourself?
Yup, floor jack, jackstands and electric impact.
The tires have to come off anyway for the carrier swap, and the exhaust ended at the rear axle. Pretty easy if you have swapped an 8 3/4 center as often as I have. I used to share a 4.56 center with my cousin's road Runner back when I was in my 'teens- I would get "visitation" every other weekeend. :tonka:
Old October 10th, 2007, 08:47 PM   #12
Cooter
Cooter's Avatar
Originally Posted by hosejockey4506 View Post
:miff: :miff:
I swap my tires by hand, as well.
XJ D44s out of the boneyard with just a hacksaw and a pair of bolt cutters in under a half hour. :miff:
Page generated in 0.24934 seconds with 59 queries
